lens centering error measurement
ganesh
Can you suggest a method to measure centering error of lens using
frame grabber
card plugged in a PC?
Our test set up is as follows--We have a autocollimating optical
head mounted
on the measuring unit. A CCD camera is placed at the focal point of
autocollimator. The autocollimating optical head is focussing in the
centre of curvature of the lens.When rotating the lens under test, if
centering errors are present, the image of the target formed on the
CCD will move correspondingly.
Presently we go by visual judgement on the CRT monitor to find out the
displacement , ( a reticle is formed through the collimator) by
seeing how many divisions the reticle has moved.
Kindly suggest a method to quantify the error with above setup?
