Display Lens Source
alfa88
Dec 1, 2010
349
I've been restoring some old equipment and run into a brick wall trying to replace the damaged front panel display window. One meter uses Nixie displays and has an amber colored window, the other uses a 7 segment led display and would need a red tint. The thickness should be ~ 0.9mm/.035" . I tried a spray tint on some vinyl page dividers obtained at a office supply store but not only did the paint adhere poorly; the clarity was miserable . Tried milling down 1/8" tinted acrylic with a Dremel. Fail. And lastly investigated several suppliers of gel filters but can't seem to get an answer on the thickness. I'm hoping there's a brainiac that knows of a source.
Externet
Aug 24, 2009
944
Look for clear-colored plastic 'dividers' for folders at the office supply place.
Or, If you find the wanted thickness in clear acrylic/plexiglas, mix fountain pen ink with clear coat and spray.
alfa88
Dec 1, 2010
349
I found paint or dyes not to durable.
I looked up polyester and sure enough Granger has something that will work.
I guess I just associated polyester with Saturday Night Fever
alfa88
Dec 1, 2010
349
The polyester from Granger turned out to be opaque. Didn't order. Then I had a brain fart. I just bought some tinted CD cases at Office Depot. Thin, transparent and in 5 different colors.
