LG DVD Player - Tray ejects after 10-15 mins.
elect_sham
May 22, 2012
3
Dear All,
My LG DVD Player plays absolutely okay for 5 - 10 minutes and then tray opens.
Anyone can help/guide me of any possible reasons and solutions.
Thanks in advance,
elect_sham
14,478
Dear All,
Thanks in advance,
elect_sham
hi there elect_sham
welcome to the forums :)
does this always happen on the same disc or any disc ?
have a closer look at the display in the moments prior to the disc ejection
maybe there is some sort of error msg or maybe you may noitce that track time is no longer advancing ???
cheers
elect_sham
May 22, 2012
3
Dear Mr. Dave,
Thanks for the reply. Please tell me what to do stepwise.
1. If the time does not advance, what is the problem. Should I adjust Focus trimpot?
2. Is there any fault related to the following:
  • Motherboard
  • Ribbon cable to m/b
  • Optical Lens
Regards
elect_sham
Wabajig
Apr 14, 2012
75
Make sure power is off. There's a limit switch in tray area that tells unit that the disk is in and out, probably dirty. Use contact cleaner (non lubricated) on switch only while moving the switch open to close. Also probably wouldn't hurt to lubricate the sliding rails lightly with lithium grease. Could only help. Good Luck.
KJ6EAD
Aug 13, 2011
1,114
It could be caused by a flaky tray eject switch or tray detect switch or the associated pullup/pulldown resistor. The fact that the fault is occuring at about the same time of each playing suggests either a thermal effect or capacitive charge affecting a transistor switching action.
If you immediately restart the unit after it fails, does it still take the same length of time to fail again? This will help determine if the effect is thermal.
elect_sham
May 22, 2012
3
LG DVD Player Model DS9481CPE
Dear Sir,
The defect may not be with "Thermal effect" as there is no fixed time limit for the tray to open. First the lens rail/gear to be properly greased and the leaf switch monitoring open/close switch.
Shall revert on rectifying the above.
Regards,
elect_sham
