Li-Ion vs. -Poly
D Yuniskis
One of my portable DVD players uses a (nominal) 7.4V 2600mAH
Li-Poly battery. One cell appears to be toast (*loaded* voltage
RAPIDLY drops from ~3.5V to ~1.8V after ~10 minutes of use;
other cell holds fast at ~3.5V).
I was thinking of replacing them with a pair of 18650's
as they occupy almost exactly the same space (different,
though compliant, form factor; same volume -- of course!).
It is my understanding that the charging technique for
LiPoly and LiIon are identical (?). I'd prefer not to have
to reengineer the charger (microcontroller controlled).
[Given my druthers, I'd replace with NiCd but that would
require way too much work!]
Any other pointers to watch for (besides the usual, "OMG!
You can burn your house down!!")?
Thanks!
--don
P.S. pointers to a source/manufacturer of reliable *tabbed*
18650's would also be welcome. (though I may just opt to
cannibalize some laptop battery packs)
Raveninghorde
Thanks!
--don
Yep, charging LiPo and Li-Ion is the same and so is the pack
protection.
Adrian Jansen
Thanks!
--don
Lots of useful info on batteries at:
http://batteryuniversity.com/
Robert Roland
The manual for one of my R/C chargers very explicitly states that
Li-Ion batteries can not be charged with the LiPo program. My other
charger has separate programs for LiPo and Li-Ion.
I know LiPo has a nominal cell voltage of 3.7V, while Li-Ion is 3.6V.
I do not know if that is the only difference.
Some Li-Ion cells are marketed as "protected". I am not sure what that
means, but maybe they have built-in protection against overcharge?
Raveninghorde
Both types charge in the same way. Constant current followed by a
float charge at 4.2V per cell.
LiPo and Li-ion cells are flat at about 2.5V and fully charged at
4.2V. The nominal voltage is pretty meaningless.
