Light bulbs as dummy load for Stereo ?
techforce
Dec 26, 2008
7
Was curious if anyone has done this before, instead of using resistors or other test gear as the load in place of actual speakers to protect the speakers?
Alec_t
Jul 7, 2015
3,821
If the bulb replaces the loudspeaker, i.e acts as a dummy load, then clearly the loudspeaker is protected :confused:.
Did you mean use the bulb as a dummy load, or use the bulb in series with the speaker to limit current?
Bear in mind that the bulb rating specifies wattage at the rated voltage when the bulb is hot. The bulb's cold resistance is a lot lower than its hot resistance.
dave9
Mar 5, 2017
1,191
You mean something you built yourself, or repaired, and question its proper function? I usually just measure to be sure there's no DC on the output (if applicable), then first hook the amp up to crappy low value speakers, actually just a loose driver I got out of something or other a long time ago.
Martaine2005
May 12, 2015
5,318
Why would you want to put a bulb in place of a speaker?,
A 120v, 60w bulb is 240 Ohms....
Martin
dave9
Mar 5, 2017
1,191
Series parallel array of incandescent bulbs in a freezer with a thermal detection liquid nitrogen spray for the win!
techforce
Dec 26, 2008
7
Yes as a dummy load. I was thinking a100w floodlight maybe. Just to protect the speakers from possible excess DC when
doing repairs. I have something like 80mv on one channel as DC offset, and the other is about 0v , doing the tests with
nothing attached to the spkr terminals. Its a Pioneer SX-240 Stereo and the protect relay keeps clicking out at about 33% volume.
There was alot of cracked solder on the spkr terminals, and one on the coil for the relay.
dave9
Mar 5, 2017
1,191
Won't a 12V bulb be too near the amp output voltage to keep the resistance anywhere near constant?
Alec_t
Jul 7, 2015
3,821
An electric kettle element would run at a lower temperature than a bulb filament, so the hot/cold resistance variation would be less.
techforce
Dec 26, 2008
7
Interesting idea. Maybe a spare electric stove coil would also do the same thing.
Good idea @Alec_t about the bulb in series with the speaker.
majoco
Nov 10, 2019
50
A 10ohm 5watt resistor is probably cheaper than a lamp.
duke37
Jan 9, 2011
5,364
I go to Rich who saves me headlight bulbs with one broken filament.
WHONOES
May 20, 2017
1,242
If all you want to do is protect your speaker from excessive dc from the amplifier output then, connect a largish capacitor in series with the speaker. BTW, 80mv offset is not unreasonable but, if it increases during usage then there is something wrong. There could be something wrong with your offset detection circuit.
bertus
3,882
As @WHONOES said, 80 mV is not that bad.
If it changes, it could be a heating problem.
Heat can make the setting go haywire.
Bertus
WHONOES
May 20, 2017
1,242
Offset detection circuits tend to be something like a window comparator (at least that's what I use). They have a largish value resistor on the input with an even larger capacitor connected from input to 0V to bypass the ac from the amp when it is up and running. If that cap' is below par, it could be causing your problem.
CircutScoper
Mar 29, 2022
300
.... but maybe < 50 Ohms when cold.
Probably more like 6 Ohms. A bulb filament when ON runs around 2000C, so a 0.5%/C tungsten tempco produces a 2000 x 0.005 = 10:1 increase in resistance hot vs cold.
CircutScoper
Mar 29, 2022
300
True -- with clusters! Less because of the lower temperature, and less again because heating elements are typically made from wire (e.g. nichrome) with a much lower tempco (e.g., ppm/C vs ppk/C) than tungsten.
