I've got another circuit drawn up that will be more robust, and suitable for a final project or design.
The first link showed a very very simple method, but it is only useful in the context that you use a 3V button cell battery and don't plan for it to last very long.
With a couple more parts you can build this. It can also be adjusted to use with different voltage sources.
The example will drive an LED, but you can just as easily make it drive a bigger load.
If you would like your circuit to be adjustable, you can lower the value of R2, and put put trim-pot or potentiometer in series with it. (Keeping a resistor there will prevent you from burning out your photocell if a very little resistance is present at R2)
Otherwise, the values used can be loosely chosen.
R2 : 300 - 430Ω (Lower values will require a darker room to trigger, this value may be changed depending on the photo-cell being used.)
R3 : 1kΩ or similar (The value here does not matter so much, as Q1 will be conducting when in a light room, so a large value is chosen to prevent excessive current draw.)
R4 : This is chosen based on what YOU want to drive. and what YOU want to power the circuit with. (6V supply, and 220Ω will provide you with 20-30mA for an LED depending on LED color)
You can grab some NPN transistors from radioshack or similar, just be mindful not to try to drive a really heavy load like a motor with them until you can look at the specs on em to determine how much current they can handle.
