Lightning rod missing on building
Skybuck Flying
There was a show on television called: "Is it possible ?" it was on the
"Discovery Channel".
There was a man, a doctor, who had electricity as a hobby.
The called him: "Doctor (Dr.) Electric"
He was standing in a cage around his body. The electric beam struck the
cage. He remained unharmed. Perhaps he was lucky, perhaps not.
Then he went into a pool with tinfoil on his head.
His head was above the water.
He had a glove of metal and a wire from the glove going into the water.
The electric beam hit the glove and he remained unharmed.
The electric beam was repositioned to hit his tinfoil hat while he was in
the water.
He again remained unharmed.
To lessons learned:
1. Electricity/electric beams/lightning follows the fastest/least resistent
path to earth/ground.
2. Electricity/electric beams/lightning dispearses (distributes) in water.
(each h2o molecule forms a path)
(Only the first few centimeters are dangerous in water)
Doctor Electric was very convincing... though they did throw some kind of
cable into the water.
And they did not show the entire cage... so there are still some doubts.
Apperently there was a cable going back to the Teslacoil/Telsalightning
device.
I remain a bit skeptical but it was cool and interesting, I kept watching to
the very end until they showed that part/what would happen.
His name is well deserved "Doctor Electric !" ;) =D
Now if he could only shoot beams from his hands then that would be totally
awesome ! ;) =D
Bye,
Skybuck.
Don Kelly
"Skybuck Flying" wrote in message
It's called a "Faraday cage"- it does provide protection- that is why you
are safe inside your car when a power line falls on it .
the water.
It appears that he was using a Tesla coil- lots of spectacular effects but
the current is generally so low that no harm is done and the frequency is
high enough that no shock is felt-Tesla used it on stage to "show" that AC
was "perfectly safe" Having arcs and corona from extremities is commonly
done.
To lessons learned:
Not necessarily-the lightning stepped leader development and local
breakdown dictates the path and this path can be pretty indirect and
unpredictable. In this way, lightning makes its own least resistant path
during the development of the stepped leader
There is dispersal- there is also dispersal in the ground when lightning
hits a tree.
If this was real lightning- he would likely be dead. The glove and foil hat
would probably be vaporized and his body.
Think how many people have died from 120V devices falling into their
bathtub- voltages and currents involved are miniscule compared to lightning.
Don't count on only the first few centimeters being dangerous.
I'm sure it was a nice show but don't try to draw conclusions about
lightning from it.
Don Kelly
cross out to reply
Skybuck Flying
Yeah,
I had a feeling we weren't getting the whole thruth from that show.
I have seen more "unthruths" from the discovery channel.
So it's a bit of an "amaturistic" channel I guess.
Bye,
Skybuck ;)
Skybuck Flying
Oh,
By the way...
There was one more thingy they showed:
Eletricity blowing up a pompkin.
How do you explain that mister ?! ;) =D
Bye,
Skybuck =D
Max Doorrijhoogte
Daar heeft geluk niets mee te maken, gek.
Had je maar moeten opletten op school: kooi van Faraday.
Don Kelly
"Androcles" wrote in message
lightning.
How many?
Many years ago I ran some tests on a borehole motor/pump unit.
The motors are filled with distilled water which acts as a lubricant
for the bearings and the wire used in the windings have a rubberised
coating). This particular motor had failed a megger test when it was
in the test tank so I added some detergent to the distilled water and
ran it. It was still scrapped because one can't drink soapy water
but it proved that soapy water is an insulator, salt water a conductor.
I haven't a count but in the old days of cheap radios without a transformer,
people sometimes used them on the side of a bathtub and accidents did
happen. Heaters were also a problem but in both situations one could
consider it Darwinian selection. This was likely not a UK problem as these
old radios had 2 prong unpolarized plugs so that there was the possibility
of a hot chassis.
Why would you want to drink the water used as a bearing lubricant- with or
without the soap? If it is distilled, surely you wouldn't want it mixing
with whatever is being pumped (even potable water ). Could it be that the
distilled water was contaminated because of a leaky seal?
Information on the net seems to indicate that detergents actually raise
conductivity- certainly low conductivity detergents (<50 microSiemens/cm)
are more conductive than distilled water (<10 microS/cm) so your observed
result might well be due to another factor such as contamination or the
absorption of metal ions over time.
What is needed is a test under proper conditions to measure comparative
conductivities. A simple but indicative test would be using a pair of clean
electrodes in distilled,deionized, tap, and soapy, water and comparing
currents at the same voltage. Going further would require a decent lab.
Don Kelly
cross out to reply
Don Kelly
Oh,
By the way...
Bye,
Skybuck =D
Let's see, 1ma at 1MV is 1000 watts- make some steam- it won't be an
instantaneous explosion but it would be faster than it would be in boiling a
cup of water. However, I don't know just what apparatus was used- some that
is used in movies is pretty impressive.
Don Kelly
cross out to reply
Don Kelly
| "Androcles" wrote in message |
| lightning.
| How many?
transformer,
| of a hot chassis.
| without the soap?
Would you rather drink oil?
http://www.alibaba.com/product-tp/112216653/Submersible_Oil_Filled_Motor_For_4/showimage.html
You can't draw water more than 30 feet high, you have to push it from
below. That means the pump and the motor have to be submersed or
else you have a very long rotating shaft between motor and pump.
For drinking water there is a risk of contamination with an oil or grease
filled sleeve bearing so the motor is water filled instead.
clean
I didn't go that far, I just used a megger. Kitchen science is enough to
show a battery and a light bulb can be connected through salt water
(bubbles of hydrogen and oxygen can be collected) but not distilled
water. I live in a hard water area, the chalk downs of Kent, and what
I measured was a fall in conductivity when detergent was added.
I suspect that the number of bathroom deaths is more Hollywood myth
than fact, although I have heard of bath salts but never used them.
Yes, I am familiar with the submersible pumps used in deep wells ( as well
as the limits of atmospheric pressure on drawing water).
However, the contamination problem in the case of your hard water well is
reversed- the hard water can contaminate the distilled water. Now, why is
the water hard? Dissolved minerals. This implies ions and higher
conductivity.
See:
http://www.globalw.com/support/hardness.html
So adding a detergent in this case could reduce conductivity but that is
not the case with soft water.
The bathroom deaths is not a Hollywood scheme( although overblown by
Hollywood)- but due to a combination of stupidity and cheapness and lack of
ground fault protection. It may be have been rare but not out of the
question. Haven't tried it personally- but in any case, the plumbing is in
plastic pipes so it provides a poor ground.
I used to have a humidifier that was basically a pot of water with two
electrodes about an inch apart- it worked nicely and a bit of salt would
increase the action.
Don Kelly
cross out to reply
Skybuck Flying
"Max Doorrijhoogte" wrote in message
Dat weet ik alang stomme lul.
Ik blijf erbij dat het geluk hebben is.
Een enkel straaltje er tussen door en je bent dood.
Herhaal die fokking proef maar eens 1 miljard keer, en dan wet ik voor 1
cent dat je dood gaat vanwege iets heeeeel bijzonders en raaaarrss..
Ga nou niet doen als het universum niet een beetje gek is ! ;) =D
En ja maar denken dat alles altijd precies hetzelfde gaat he ! nou moooooooi
niet dus ! ;) =D
Doei,
Skybuck.
Max Doorrijhoogte
Niet gehinderd door enige kennis van zaken...jouw mening gaat boven
wetenschap..... heerlijke humor!
Don Kelly
and prior to that time, the only electrical device most people had was a
light bulb. Some had motors but there was no need for these in a bathroom or
kitchen.
And the drain was bare metal- connected to the plumbing which was likely to
be cast iron or even copper- ground path existed.
and has done in many- I had to deal with a situation- it appeared that the
victim touched a toaster and a refrigerator (with no safety ground) at the
same time. 120VAC does it- not as fast as 240V but, because you have worked
with 240V -don't dismiss the "measly 120V" hazards.
Now you are calling on Hollywood. By the way, Edison proposed AC for the
electric chair- and it was accepted by the state- he wanted to show that it
was dangerous- the last thing he wanted was to have people see any dangers
with DC- see the Edison-Tesla "wars".
Right here: http://tinyurl.com/63fzqk6 I didn't watch the
clip. Commentary
about the show in other places said they confirmed that people can be
killed by
bathtub electrocution.
This is apparently in Germany: http://tinyurl.com/blmmd9 (230
volts, 50 hertz? )
"30 of the cases were suicides (75%). In 11 of the suicides a farewell
letter was found; in three cases evidence of another concurrently
attempted
method of suicide was observed. One case was a homicide, 6 cases were
declared as "accidental" and in 4 cases the autopsy findings and the
inquiries of the police did not allow a clear determination of the
circumstances of death. Information concerning clothing in all cases was
rare; concrete information was given in only 11 cases. (1 victim was fully
dressed, 4 victims were scantily clad and 6 victims were nude) Signs of
drowning were found in 7 cases, 2 of these victims had a clear cutaneous
electric mark. "
What that is telling me is the bathtub is instrumental in being part of
the
conductive path but isn't the primary cause of death. One could as easily
grab the toaster and the kitchen sink. Having once got my hands across
415V
I can tell you it was extremely unpleasant, but I'm still alive to talk
about it.
From the New York Times: http://tinyurl.com/42y9626 Two kids
were killed
in Forth Worth, Texas.
Sceptically accepting that as factual, it still amazes me that it is
possible.
What was a socket outlet doing in a bathroom with two unsupervised
children
of opposite sex, in the bible belt no less, to begin with?
Maybe times were more innocent way back when.
Oh sure, that was before Catholic priests were paedophiles - or
before we naively thought they'd never do such as thing as
molest a child.
Some more info here: http://tinyurl.com/4xnlk2o
( Journal of the American Medical Association)
Abstract:
From 1979 to 1982, in the United States, at least 95 persons were
electrocuted in bathtubs; 66% of the deaths occurred during the winter
and spring. Children younger than 5 years had the greatest mortality
rate, and hair dryers were responsible for 60% of the deaths. Until
electric appliances used in bathrooms are made safer, the appliances
should be disconnected when not in use, not used in wet bathtubs, and
kept away from children.
End quote.
There is a link to a PDF with the full text toward the right hand
side.
No mention of the percentage of suicides and a call for appliances
to be safer! In Britain there are no normal sockets permitted, the
light switch is ceiling mounted and operated by a pull cord and
the switch for the electric shower is outside the bathroom. A
lower voltage shaver socket was permitted years ago but I've
never seen one. Possibly they exist in hotels.
But all this completely misses the point.
How does the current pass through a human body, insulated by the
vitreous coating, from the hair dryer to the drain ?
The nice shiny conductive ring that fits inside the drain opening and
connects to the plumbing.
I mean really, a bird can alight on overhead power lines and be
unharmed, that's no different to dropping the hair dryer into the
water in the bath tub when your butt is sitting there. Unless the
bird or you are part of the circuit nothing will happen.
The situation is different now- GFCI devices are mandatory in bathrooms,
Prior to this shaver outlets had isolating transformers. Also bathtubs are
mostly fiberglass and the plumbing lines are plastic so the tub and sink are
isolated.
In that case there is no good parallel path to ground.
By the way, note that birds (particularly larger ones) do not sit on EHV
transmission lines - they don't care for corona discharges from feathers and
beaks- this has nothing to do with the bathtub situation as it was and
little more to do with it as it is- there is no path other than a lot of air
to anything else.
Don Kelly
cross out to reply
Skybuck Flying
Nee ook voor jou geldt, gebaseerd op ervaring.
Mensen denken het allemaal zo goed te weten... maar dat is helemaal niet zo.
Vraag je zelf maar eens af waarom al die vliegtuigen toch steeds blijven
crashen...
Ze wisten het allemaal toch zo goed ?! ;) =D
Nou ik heb inmiddels genoeg stommiteiten gezien in vliegtuig ontwerpen
hoor... ik stap er mooi niet in... never ! ;) =D
En dan zwijg ik nog over toevallige samenloop van omstandigheden die jij
niet voor mogelijk houdt ! ;) =D
Bijvoorbeeld:
Wat dacht je van een vogeltje die over jou faraday cage heen vliegt en even
een plasje maakt !
Daar ga je dan ! Dood ! Wees gegroet marie vol van genade de heer zij met U
! ;) =D
Doei,
Skybuck ;) =D
Don Klipstein
Abstract:
End quote.
There is a link to a PDF with the full text toward the right hand side.
In my experience, 100% of bathtubs have drains having metal parts that
get exposed to water as soon as a liter of water gets into the bathtub.
And, in older houses and even modern ones in a few older union-town
cities, the drain pipe is often metal. If I build a house in Chicago or
Philadelphia nowadays, its toilets need to dump into sewer line via
metal pipe.
Max Doorrijhoogte
Bijvoorbeeld:
een plasje maakt !
! ;) =D
Doei,
Skybuck ;) =D
Tja als je de omstandigheden van het experiment verandert, kunnen ook
de uitkomsten veranderen.
Maar vogels urineren niet voldoende voor deze stelling, helaas.
En dan nog hoort dit niet thuis in nl.politiek
Skybuck Flying
Ja je kunt wel blijven doorzeiken, maar feit blijft dat die gast helemaal
niet de omstandigheden in de hand had ! ;) :)
Die gast die stond gewoon buiten ! ;) :)
En dat is het hele punt ! ;)
En of een vogeltje nou wel of niet genoeg plast doet helemaal niet ter zake,
voor hetzelfde geld landt die op de kooi en pikt hij je in je gezicht en
maakt
daarmee een verbinding met jou en dan is het game over ! ;) =D
Doei,
Skybuck.
Skybuck Flying
"The Ghost In The Machine" wrote in message
Pattycakes, you retard. Usenet is international in nature. In particular
you failed to notice this was crossposted to two nl.* groups. nl stands
for Netherlands. Perhaps you've heard of them. Holland, the Dutch,
windmills, tulips. Guess what? They speak Dutch there, not English!
(and you grossly misspelled Dummkopf. Wrong language, too!)
UP YOURS MORONIC !
TGITM
Try google translate lol, and post it here if you have any further doubts or
question about what I wrote ! ;)
It might actually be interesting for you ! ;) =D
Bye,
Skybuck =D
Skybuck Flying
Or in this case, what he wrote... lol :)
Bye,
Skybuck =D
Max Doorrijhoogte
maakt
Doei,
Skybuck.
trol
Don Klipstein
Look at the cartoon:
Q. Does Homer get the beer?
A. No if the tree is wet, yes if it is dry.
Many of those lines are 2300 or 4600V, and live trees are usually not
good insulators.
