/dev/phaeton
- Jan 1, 1970
- 0
Hello!
I have constructed a 555 based oscillator. The schematic is here:
http://www.uoguelph.ca/~antoon/circ/555test.gif
but as you can see it is a 'standard practice' type of circuit. I made a
few modifications to alter and adjust the frequency of oscillation
(replaced a resistor with a pot and shrunk the size of the cap). I will
be using this to inject a signal into an audio amplifier for diagnostics.
Nonetheless, when powered by the convenient 9V battery, the amplitude of
the output is several volts (as expected). I would like to
1) limit this to under 1V maximum, and
2) block any DC from entering the amplifier's input.
Is it easy enough to simply put a capacitor inline with the "Optional
Pulse Output" in the pic to block the DC, and then use two anti-parallel
diodes connected from there to ground to 'cut down' the
signal? AFAICT the diodes will safely reduce the signal down to ~0.6V for
your garden variety silicon signal diodes (1n914, 1n4148, etc) and ~0.3V
for the oldschool GE types. Sound plausible? Is there a better way to go
about this?
Thanks for any feedback,
-phaeton
about this?
-phaeton
