Ralph D.
- Jan 1, 1970
- 0
Background:
I desire to install a 5000 BTU electic radiant heater to keep a
section of the garage warm for our outdoor cats that enter garage via
pet door. I intend on supending the unit on chains about 1 1/2 ft
below the joists. I have read that cats should not be left at below
45 degrees for sustained time. I am in Tennessee and the garage is
set-up with cat blankets and never freezes, so the QA on this doesn't
have to be 100%. The three cats ahave been raised indoor/outdoor, but
won't be back inside for allergy reasons. I want the radiant heater
to activate whenever the ambient temperature in the garage hits about
48 degrees. I want the setup to be safe enough so that I don't have
to worry about house burning down on vacations. I will also be using
the heater when working in the garage that serves as a cramped shop.
Approach:
I intent on purchasing a dipole (4 wire) line voltage thermostat that
connects in series between the 120V power supply and the the heater.
I am leaning toward the CADET T410B. An installation manual for a
similar model recommends taping up any ground wires.
Question(s):
Is taping up the ground wires smart? Should I install a GFCI outlet
to compensate? Any other ideas on how to get this done? (getting rid
of the cats is tempting, but not an option
I would like to keep
the up front costs under about $150. I think an electic radiant
heater is the way to go since I don't want to pay to heat the whole
garage and I like the thermostat since I don't have to worry about
checking the weather and turning the heater on/off.
Approach:
Question(s):
