I've have this LED light with adjustable colors. It it based on LED strip with interleaved yellow and white leds.
The problem is if you turn off the power it does not have memory, and when powered on, the default state is to turn on
White LEDs only, in order to light up the yellow ones as well, a remote is needed.
I don't care about dimming, I don't care about color change, and don't want to use the remote, all I need is both LED types to be at max power. Always! From the moment I turn on the power at the main switch.
I've tried finding a similar LED driver without a remote, or even just a single channel driver with similar V specs and ~400mA output so I can just attach to both LED chains in parallel, but can't find any.
How can I achieve what I need?
Any advise is welcome.
Thank you so much!
Thank you so much!
