Linear Freq Ctrl for XR2206
Dennis Kent
Could anyone please post a circuit here that will provide a linear
adjustment curve for the frequency control pot on an XR2206 function
generator IC?
I recall seeing one but can't find it anywhere now.
Thank you,
Dennis Kent
Ban
generator IC?
Thank you,
Dennis, since the current out of Pin7 resp Pin8 is linear with frequency you
could use a current sink instead of a resistor.
f(Hz)=320*It(mA)/C(uF)
The range can be from 1uA to 3mA. The compliance is around 3V.
The current sink can be made with an opamp with a 1k sensing resistor driven
by a pot from a 2.5V reference for example. If you use a logarithmic pot,
you can get a respective curve.
2.5V pin7
o o
GND '----------o
single supply opamp |
1k| |
GND
(created by AACircuit v1.28.6 beta 04/19/05 www.tech-chat.de)
Dennis Kent
This is very helpful. Excuse me for being dense, but what does the
symbol below pin 7 represent.
Dennis
Ban
It is a small N-Mosfet like VN1310N3 or BSS100, also a bipolar will work,
but might need compensation to not oscillate. The Gate is left, the Drain
goes to 7 and the Source to the resistor. The current is Vin/1k, so 2.5V
will give you 2.5mA and 0.001V will result in 1uA. So a precision opamp
should be chosen like TLC2201 if you need the full range.
