Hello!
I have two questions:
1.) Is it possible to have a linear power supply for 100W led like this Yuji-led? I have only found switching PSUs.
store.yujiintl.com
Here's the datasheet:
I would like to get totally rid of the electromagnetic interference and switching power supply. I would need DC-DC PSU, not AC.
2.) Would it be possible to use that 100W Yuji led with two normal 12V batteries (24V)?
Forward voltage seems to be 23V-27V.
What happens if I just put two 12V batteries together to get 24V and put it straight to the 100W led? Do I need some resistor in between?
Thanks!
, Pete.
YUJILEDS® CRI 95+ High Power 100W Flip Chip COB LED 3200K 5600K - 160H5600K / 1pc
YUJILEDS high CRI high-density 100W LED COB provides 95+CRI high quality light and 6000lm output on a tiny φ9mm surface. It is more compact and denser than most existing COB packages on the market and is perfect for all applications requiring high quality light enviroment.
store.yujiintl.com
https://cdn.shopify.com/s/files/1/0344/6401/files/YJWJ020-1.1_YJ-BC-160H-G01.pdf?8015580825686102054
Thanks!
, Pete.
