LM317 Help
Dave Benemerito
Sep 26, 2015
24
I have a SIM800L module with no voltage regulator on it. I have power it between 3.7V to 4.4V. I was using LM317 to regulate the power from the supply (4.6 to 5V) using two resistors 220Ω and 470Ω
When building the circuit, the output voltage was 3.1V which lower than recommended and might damage the module in my opinion
I have never powered the module. I would like to ask help what to do before i could damage the board. Thanks! :)
Chemelec
Jul 12, 2016
291
You need to get an "LDR" Type of Regulator.
LDR = LOW DROP OUT.
The LM317 has too High of a Voltage Loss between Input and Output.
dave9
Mar 5, 2017
1,191
If the power supply is low enough ripple, just throw a silicon diode in series with it to drop ~ 0.7V
