pawihte
- Jan 1, 1970
- 0
The specs for the LM317 says that, since it uses a floating
circuit, it can be used at high voltages as long as the
input-output differential is within max ratings. But practical
loads will place a capacitance at the output of the LM317, with
many having a physical capacitor. That capacitance will
momentarily short the output to ground at switch-on, causing the
LM317's max voltage rating to be exceeded. An example would be a
fast-rising 100V input and a 75V output with a large cap at the
output. Is this likely to damage the LM317?
