lm324 op amp
SioL
Winfield Hill said:
Joerg wrote...
Not that bad... For example, Vishay BAT82S (44348 in stock),
SD101A (16922 in stock) are both $0.03, qty 1k at Newark, $0.05
in singles, and the LS101C smd part a bit more, $0.04 for 1k...
BAV70, dual SMD schottky.
SioL
Joerg
Hi Winfield,
That is a good price for a Schottky diode. Wish they were in SMT though.
This could actually beat the transistor which can be had under 2 cents
but it needs a resistor for base current and that adds a penny back in.
The BAT54S is SMT but over 10 cents. Well, at least you get two in one
SOT23 pack for that. They are nice for building mixers.
Regards, Joerg
Spehro Pefhany
Joerg wrote...
Or the very available BAT54 (SOT-23) 200mA/30V $0.03 in 250 at Mouser
or Allied.
Best regards,
Spehro Pefhany
Tim Wescott
Tim said:
Ha! That was an enjoyable little read. I especially liked
The figure was drawn with thermionic tubes to avoid any suggestion of
partiality in favour of any particular semiconductor device. Since
thermionic devices at present are not generally available in IC chip form
I'd never seen that section of their website, I gotta read the rest
now :)
Tim.
"Not _generally_ available". I didn't even notice that -- I just
searched down to the section on phase inversion to make sure that it was
what you were looking for. Now _I_ gotta read it...
Joerg
Hi SioL,
These are not Schottky but regular diodes. They are great diodes and I
just used them in a design last week. Basically the same as BAV99 except
that the BAV70 is common cathode.
Regards, Joerg
M.Randelzhofer
Joerg said:
Hi Winfield,
Regards, Joerg
The BAT54xW in a SOT323 / SC70 case seems to be much cheaper. A 3000 reel
costs me 2.5 euros per 100 - the SOT23 was 8.5 euros.
MIKE
John Larkin
Hi Winfield,
Regards, Joerg
But be careful: a small-signal schottky may not conduct hard enough to
protect an LM324!
John
Joerg
Hi John,
protect an LM324!
The OP was only concerned about the input where you could limit the max
current. But you have a point here since the LM324 abs max is spec'd at
300mV. Less than a Schottky would offer. So I'd still favor either the
reversed transistor or a pre-biased silicon diode.
Regards, Joerg
Joerg
Hello Mike,
Thanks! That sounds much better even though a Euro is now over $1.20.
But ON Semi makes these, too, so we have a domestic source. Hey, we even
can get Spaten Oktoberfest Beer over here :)
Regards, Joerg
N
N. Thornton
Spehro Pefhany said:
And nothing over a dime or two, please. ;-)
Best regards,
Spehro Pefhany
and thats the beauty of the 324... any time it can handle the app, its a winner.
NT
Daniel Haude
On 10 Oct 2004 03:17:51 -0700,
now :)
Same here; I think it's fantastic!
--Daniel
Jim Thompson
Has anyone found this problem,
When a negative voltage is connected to the input of this op amp the output
will go positive, and the other outputs will go slightly positive.
Do you know what causes this?
Duh!?!?
...Jim Thompson
