lm337t
Kevin Weddle
Feb 23, 2004
1,620
I have to fix the kit I have. The regulator seems to give out under higher currents after a brief while. I replaced the positive variable voltage regulator with the lm317t. This was easy to configure because I had the diagram. The lm337t which is the negative variable voltage regulator does not have a diagram. Should I use the same configuration because National does not specify the diagram for this particular device? It only specifies the configuration for the lm337.
By the way, I had to rig the kit to my custom which I don't normally like to do. It has to be done because I don't like the voltage dropping out and plus the traces are starting to screw up and I have to connect the components with wire.
MP1
Dec 7, 2003
3,399
Kevin,
Here is the data sheet.
MP
LM337.pdf
  • LM337.pdf
Similar threads
Replies
1K
Terry King
