Jamie
- Jan 1, 1970
- 0
Hi all,
I have just made a regulator using LM338 TO-3 Reg.
I have 32V DC 5 amps as the input to the reg, and the reg is reducing this
to around 14 volts.
I have a 240 ohm resistor from the adj to the out of the reg, and a 5k 10
turn trimpot from the adj to the circuit ground.
The 240 ohm is connected directly to the reg case.
Protection diodes are installed as per the lm338 datasheet, and an 0.1uf
ripple cap, from the adj pin to ground parallel with the 5k variable res.
The problem is if i test the unit by connecting a 6 ohm 10 watt wirewound
resistor from the output of the reg to ground, my output voltage drops from
14v down to around 6-7 volts. The 6 ohm resistor represents a ~2 amp load,
The reg should be stable up to 5 amps??
The input voltage does not drop when the load is applied, only the output
voltage.- any ideas why??
If anyone has any suggestions, please email me
[email protected]
thanks in advance
jamie
to around 14 volts.
[email protected]
thanks in advance
jamie
