So i started to make a portable bluetooth speaker and decided to use some left over laptop L-ion batteries (i do love a cheap and easy way out of things). But of the very little i know of electrical circuitry one of the main problems i could see is over discharging. So i found a simple little circuit using a LM339 to display a low battery alarm (below) but because i plan to be hardcore raving when the battery runs low i don't think an alarm will cut it (i would most likely ignore it). So my question is, is there any way to have a light come on (this part i can manage to get to work) at a little over 12 volts (4 cell l-ion) as well as have a relay that cuts it off at anything below say 11.5 volts. do i need some sort of signal inverter, any that doesn't require more ICs or transistors would be great but not mandatory. Please keep the technical jargon to a minimum, i've lost enough brain cells to inhaling solder fumes already
Thanks for any help
SimpleJoe
Thanks for any help
SimpleJoe
