Robbo
- Jan 1, 1970
- 0
I'm running a couple of LM34 temp sensors into a PIC16F687. When running the
ADC result is noisy.
Here's what I've got:
1) On the LM34 temperature output pin is a sawtooth of about 200mVpp and
150uS period: |\|\|\|\|\
The 150us period seems unrelated to the ADC sampling rate - this which is
sampled "on demand".
2) The ADC is set up for external reference (2.5V) which is clean and
stable.
3) The LM34 supply and grounds are also clean and stable. I've tried
powering them from both 5V & 9V (battery).
4) A couple of 5k pots set up on the input work perfectly, the wiper
voltages & ADC results are stable & smooth.
5) The LM34 outputs are coupled via a 10 ohm series resistor followed by a
10nF cap to ground as follows:
LM34 --/\/\/\---------> ANx on PIC
10R |
--- 10nF
AGND
6) Stuffing around with the code, reducing it to the bare minimum does not
change anything.
_However_ I've found that removing the 10nF capacitor _fixes_ the noisy
operation of the LM34's. With the cap in it oscillates - with no cap it is
stable. I can't see anything in the LM34 data sheet about capacitive loading
the LM34 output. Zout is low 0.4R @ 1mA.
Am I missing something obvious here? Any suggestions greatfully received!
TIA
r.
stable.
10R |
--- 10nF
AGND
change anything.
TIA
r.
