Hello All,
Just finished building a modification of the following circuit.
http://www.uoguelph.ca/~antoon/circ/vps.htm
The changes I made were to use a 24v 3a transformer as this was available at the time. I also used an LM350 instead of LM317 as it is rated at 3A. Also used a 2A fuse and some other small component changes due to availablility. The LM350 is a metal can type on a large heat sink.
So, the unit works and will power a 12v 10 watt light. The voltage varies nicely under this load and also without load. However, when I try to power a 35 watt halogen light, nothing!
I suspect that the LM350 might be cutting out due to current overload. Could this be the problem?
Would fitting an LM338 (with 5A rating) be the cure?
I originally built this as a general power source for use in cutting foam with a NiCr wire, so think that I will need to draw quite high current.
By the way, I am an electronics beginner so any help is greatly appreciated
