LM383
H
Herman
I am in need of 10 or so LM383 audio amplifiers. They are obsolete. If any
one has a few to get rid of I would be grateful. reply to rike2 at
bellsouth.net.
Ross Herbert
:I am in need of 10 or so LM383 audio amplifiers. They are obsolete. If any
:eek:ne has a few to get rid of I would be grateful. reply to rike2 at
:bellsouth.net.
The LM383 is often reputed to be a reverse engineered TDA2002
http://electronica-hobiku.blogspot.com/2007/11/lm383tda2002-amplifier-module.html
Quasar have a kit which says the TDA2002 or TDA2003 are a direct dropin
replacement for the LM383.
http://www.quasarelectronics.com/kit-files/electronic-kit/3047.pdf
TDA2002
http://pdf1.alldatasheet.com/datasheet-pdf/view/54784/FAIRCHILD/TDA2002V.html
While the TDA2002 is obsolete the TDA2003 is still current from ST
http://www.stmicro.com/stonline/products/literature/ds/1449/tda2003.pdf
At a pinch you may find the TDA2030 (higher power) is also a suitable drop-in
but you would need to investigate further.
http://www.stmicro.com/stonline/products/literature/ds/1458/tda2030.pdf
