lm7805 getting really, really hot
rickselectricalprojects
Feb 1, 2015
118
hi everyone
i made a 5v power supply using a 7805 regulator that i salvaged from an old tv. i have an input voltage of 12v and when i connected it to a dc motor which draws 0.8a the regulator got over 110 Celsius (or 230f for americans) and i have a heatsink on the regulator. i know that linear voltage regulators are very inefficient but should they get that hot?
there is a 10uf cap on the input and a 10uf cap and a 0.1uf ceramic cap on the output.
the temperature depends on the amount of heat generated and the rate at which it can escape (the temperature rises until the two are equal).
In your case, the heat comes from the voltage difference multiplied by the current.
Either:
a) use a larrger heatsink
b) reduce your input voltage to 8 volts or so
c) use a switchmode regulator.
Feb 1, 2015
118
Either:
thank you for your help, i will try using a bigger heatsink.
duke37
Jan 9, 2011
5,364
The 0.1μF capacitor, together with its leads forms a tuned circuit. The regulator consists of a reference and a very high gain amplifier. If the tuned circuit is at a low enough frequency where the amplifier gain is high, then instability can occur.
Saying that, I have never encountered instability.
