Two LM7805’s
Martaine2005
May 12, 2015
5,318
This is probably the stupidest question ever!.
Can the two regulators share a heat sink without insulating them?.
My heart says no and my brain says yes as -neg and tabs are electrically connected.
Both regulators are on the same 9V rail too. So are in effect already connected together via the -neg rail. The outputs go to separate boards which also share the common -neg rail.
Can someone please clarify this either way?.
Thanks. Martin
14,317
Of course they can. If they share a common GND, that is. The tabs on the TO220 case aer connected to Common aka GND:
Instead of using two 7805 you can use a single 7805 plus an external transistor to increase the max. output current like e.g. so.
Martaine2005
May 12, 2015
5,318
Thanks for the clarification #Harald Kapp. I really should trust my brain:)
I knew deep down but wasn’t 💯 sure.
Regarding using only one regulator, I have loads and they cost nothing. Plus, it keeps it simpler for me.
Thanks for the link, it’s a hard read (terrible English) but I’ll bookmark it and read it again.
danadak
Feb 19, 2021
1,104
Using two regs gives you the full protection each reg has, eg Thermal,
short circuit. A simple boosted reg does not have full protection.
Martaine2005
May 12, 2015
5,318
That’s a really good point that I never considered. It’s simply that I have loads of them.
Thanks @danadak
AnalogKid
Jun 10, 2015
3,058
ALWAYS check the datasheets for exceptions, but --
The tab of a TO-220 package *usually* is connected to the center pin. This is true for both power transistors such as the TIP series, and 3-pin ICs such as regulators. I've seen some parts where the tab is GND but none of the 3 pins are.
ak
Martaine2005
May 12, 2015
5,318
Thanks @AnalogKid .
Both negative terminals are electrically connected to tabs. It was a school boy question.
If you don’t know, ask an expert!.
Cheers AK
bertus
3,877
Do you also intend to connect the outputs?
There will always be a slight difference in output voltage.
This will lead to imbalance.
Bertus
