lm7812 problem
jpp412
Mar 3, 2005
17
I have a problem with a 7812 in a power supply such that the output voltage (measured with a dvm) is only 9.5v.
I at first thought the 7812 was bad so I put a new one in and still getting the same results.
I have a 7805 and 7905 in the same supply that work fine.
Any thoughts?  Is is possible that I got a batch of 7812's that are no good? (or perhaps mismarked 7810's)
Thanks in advance.
Joe
Kevin Weddle
Feb 23, 2004
1,620
I would suggest you determine the pin out to be correct. I did that with some voltage regulators. It turns out that I could not get the package pinout of the IC over the internet. So I just guessed until I go the correct voltage.  In the process I think I destroyed the regulator.
jpp412
Mar 3, 2005
17
I don't think that's the problem - at least based on what I had ordered the 7812 was from TI and I used the pinout on their datasheet.  However is there someway I could check it? - short of removing it from the circuit and using separate test circuits?
audioguru2
Apr 6, 2004
12,026
Hi Joe,
Is the input voltage at least 15V at its lowest points during ripple from the rectifier's filter cap?
jpp412
Mar 3, 2005
17
Hey Audio,
Yes it is about 18v according to the DVM.
jpp412
Mar 3, 2005
17
I haven't even connected any load to it yet - the regulators are cool.
ante1
Jan 24, 2004
4,138
Hi jjp,
Is it possible to measure the current going through the earth pin?
Thomas1
Feb 20, 2005
29
Hi jpp,
Did you probably forget the filter caps of 100n and 330n near the regulator?
ante1
Jan 24, 2004
4,138
Hi Thomas,
If you get a problem because you forget the cap at the input the problem is usually a very hot regulator due to self-resonance (swing). The cap at the output will not affect the regulator at this stage since there are no load variations without any load.
It would be interesting to see the schematic!
