Logic family selection
Sravanthi
Feb 4, 2015
72
Yes, the fact that you cannot rely on an open TTL input to float to a high condition. It floats high by accident, not by design. It is a relatively high input impedance condition, and radiated noise can cause the input to transition. For any logic family at any time, never leave an input floating.
ak
Thank you for reply..
Then Pull up resistor is an acceptable solution for OR gate.
How to construct AND gate with those 2 requirements??
Help me in making this circuit.
AnalogKid
Jun 10, 2015
3,058
Here is what I think so far. Section A is the two input signals. Section B is a bare minimum approach. Section C is a more traditional approach. These are designed to drive a CMOS logic gate input. Note that both B and C end with a pull up resistor as indicated in previous posts. Depending on the voltage and current for the input signal, Section C might need resistors in series with the bases. Also, these circuits need to be tested with a 40 us pulse signal.
ak
  • AND-Gate-1-c.pdf
AnalogKid
Jun 10, 2015
3,058
I have a requirement to the OR gate as open input(This may happen with some failure to the input eg like PCB track cut) ...
This is a strange requirement. How can this happen? Where is this pc board going to be located where its traces can be cut while in operation?
ak
AnalogKid
Jun 10, 2015
3,058
Pretty sure that doesn't matter, unless the control system is mounted to one end of the table...
ak
Sravanthi
Feb 4, 2015
72
ak
This may not happen.
Since I am doing FMEA(failure mode effect analysis) I have to consider all the failures.
Sravanthi
Feb 4, 2015
72
ak
Thank you for reply...
Here also requirement 2(mentioned in 7 th post) is not satisfied (The component, (eg. transistor or MOS) which takes input fails in short/open, output should goes to logic zero).
Consider Section B schematic.
If A input is logic 0 and B is logic 1 and D3 is failed in open then output is logic high,which is not as per requirement.
The similar problem exist in section C schematic,
If A=0 and B=1 and Q1 failed in short then output goes to high.
How to solve this
AnalogKid
Jun 10, 2015
3,058
No, you don't. You have to consider all *reasonable* failures. The circuit might fail because it was hit by an asteroid, but I would not spend design time trying to account for this.
ak
Sravanthi
Feb 4, 2015
72
ak
Open input to the AND can be solved with pull down resistor. Even though its not reasonable it has to be considered.
Transistor or diode failure in short and open are reasonable failures. But this problem is not solved with the given schematic.
So please consider this problem and give me a solution.
Thank you...
AnalogKid
Jun 10, 2015
3,058
Automatic handling of all possible error conditions is not possible.
An absolute solution is not possible, because both failure logic states also are valid logic states for normal operation. If the input is a continuous waveform with a minimum frequency, you can add a monitor circuit to detect if it has stopped in either logic state. But that is a large increase in circuits, and now you have to worry about a device failure in the monitor circuit giving you a false alarm, or missing a valid alarm.
You need to put firm boundaries on your requirements, because automatic handling of all possible error conditions is not possible.
ak
Sravanthi
Feb 4, 2015
72
ak
I agree with your point,that addition of extra circuitry for monitoring will make circuit complex.
My aim is not to add extra circuit for monitoring and giving indication that it has failed. When ever one of the transistor or diode fails it has to drive AND gate output to zero. Does this not possible with simple additional components in series or parallel to diode or transistor.
Thank you...
