Hello
I recently started a project, making a step motor controler board using IRLZ44 Mosfets (hex Mosfets) to control the power source to the motors. The way I understand them is they are either on or off no inbetween so if I set the circuit fo 12 volts when the mosfet is trigered 12 volts is sent.
The board I am working on is using 5 volts for logic and 12 volts for the motor. Someware I read in order for the
hex-mosfets to work the input voltage has to be twice the output voltage, so that would mean I would have to put 24 volts to the board, the step motors are only rated for 12. So back to were I don't know what I am doing.
this is the board I am working on http://pminmo.com/3axis/3axis.htm
thanks for any help you can offer.
gogo
gogo
