tecjim
- Jan 1, 1970
- 0
Does anyone know of a devise or sensor that can indicate a signal or no
signal for a forward movement, but have a signal for a reverse
movement?
Or is it impossible to do?
I am open to any other solutions that someone can tell me
Description of project is that
1. It has a flat surface to mount to
2. It has wheels for mobility for the movement of a forward or reverses
(push or pull)
3. Power supplied 12v DC 20amp
4. To be used for out-door use, subject to extreme weather conditions
and temperatures.
Example:
Take a child's red wagon being pulled or pushed in different
directions.
Pull the wagon towards you and walk "prefer a signal
Stop "prefer a signal
Push the wagon backwards "signal "
Now pull the wagon towards you and walk "prefer a signal
The specs should fall into this area
Sensor Specifications:
1. Bi-Directional
2. 1-3 phase signal, reverse motion and stationary (non movement)
3. Generate a signal reverse or opposite direction from a forward
motion
4. Time delay adjustment
5. Temperature rating -40°C - +50°
6. .5v - 12v DC .01amp
7. Sealed unit
8. Weather proof
9. .002% accuracy
10. Vibration tolerance adjustment
11. To be used in an external application only
12. No moving parts or external reference
13. Non magnetic
14. PC programmable
Something like a digital compass? I'm not that experience in this field
movement?
(push or pull)
and temperatures.
Example:
directions.
1. Bi-Directional
motion
7. Sealed unit
8. Weather proof
9. .002% accuracy
13. Non magnetic
14. PC programmable
