O
OBones
- Jan 1, 1970
- 0
Hello all,
I'm looking for a distance sensor to be used in a situation where I need
to mesure the distance from the sensor of an object moving toward or
away from it without noticeable lateral movement (and I don't want to
measure it anyway). The object is always different but all possible
combinations are showing an almost flat square surface of 20 centimers
side and cannot be tempered with so the sensor has to work on its own.
With this measurement, I want to give feedback (visual, audible, to a
supervisory system...) of that distance considering that anything closer
than 5 centimeter is considered "too close" and anything farther than
200cm (approximately) is considered "too far".
I don't need great precision, and if I was to use an ADC for reading the
analog value, 8 bit would be enough giving me a resolution of roughly
1cm. Note that I would prefer a linear sensor but it doesn't have to be.
For instance, it could be that the greatest precision is obtainable
between 5 and 100cm (80% of values for instance) and less precise
farther than 100cm. I would need however to distinguish between the "too
close" and "too far" states.
As the system will have to run on batteries in most installations, I
would like it to consume as little energy as possible with the possible
help of microcontroller turning it on and off on a regular basis. Having
a microcontroller on the board is almost granted for the whole system to
work, so it should not be a problem to add the management of the sensor.
For this kind situation, I know of laser, infrared and ultrasonic
sensors but I'm not sure what would be best suited considering the "low
current" requirement. Nor do I know if there is a better kind of sensor.
So if anything comes to mind to anyone, please do not hesitate to point
me in the right direction.
Regards
Regards
