Looking for datasheet 9435M / 425212
I need a datasheet (or any info) about an 8 pin surface mount chip. It
has the markings 9435M and 425212 on it - i'm hoping it's some kind of
5V reg but can't be sure.
TIA
Lostgallifreyan
F
FJF
F
FJF
Lostgallifreyan said:
Well, you got a tad further than I did, you found a PDF at that address.
Did you look at it though? :)
That's for some LSI with lots of pins, it's not the little SOP-8 thinger in
that picture the first poster showed us.
Try 9435M instead of 9435/D...
......not 1st PDF.....get the second it´s called VMOS 30V / 6A.......
Lostgallifreyan
.....not really i got 3 .
http://www.hqew.com/EN/DataSheet/Result.asp?keyword=9435
----> take P-FET because you pic shows a VCO!
greetings
FJF
Well, it was your link I followed...
But sure, your new one gets three. (And neither 2 or 3 seem to have a
PDF anyway). I'm not sure that P-FET is the right one, but it might be. The
IC form is right, but 9453M might be a very different thing.
I did find a link (posted earlier) suggesting Xicor as one maker, so
writing to them might get something specific to that exact code of 9453M.
To continue with Google I think it is best to establish some makers for
that exact device code before looking for data sheets anyway, the only
reason I tried to grab one is because it appeared to be offered by that
hqew.com site but I couldn't find one. So far neither of us had found one
there, and there probably isn't one.
I
ian field
That's a clue - I think it might be a dual power MOSFET.
F
FJF
Just trust! It is a P-FET because the pictures show a VCO PCB !
Otherwise ......open a new .........posting for help and beginn a new
discussion. :))
greetings
FJF
Philip Pemberton
That's a MOSFET of some description. Pins 1-3 and 5-8 are wired together.
Industry standard pinout is:
Pins 1-3 Source
Pin 4 Gate
Pins 5-8 Drain
9435M is just the main part number, the prefix has been dropped. Assume for a
moment it is a MOSFET - we Google for "9435M MOSFET". One of the results is
<http://www.diodes.com/products/appnote/pdfs/power/sw_reg/ANP004_AP2001.pdf>.
Page 7 in fact. That gives us the part numbers "CEM9435" and "AP9435M".
So we Google again for "AP9435M" and we find
<http://www.jlink.com.tw/Datasheet/APOWER/AP9435M.pdf>, which is a datasheet
for the AP9435M.
That any help?
