Looking for Precision Resistor Datasheet
RobHid
Jan 30, 2023
3
the attached picture shows two identical (through-hole and radial) 600 ohm resistors connected in parallel to obtain a shunt resistance of 300 ohm. There are the following notations on the package: "MW02 600R 0.5/E".
I suppose they are metal foil precision resistors, but I cannot find their datasheet on the web. Could anyone recognize them and help me to recover detailed information (tolerance, TCR, rated power...)?
RobHid
Jan 30, 2023
3
Unfortunately, I cannot show any link to the origin of those resistors, because I found them installed in a measurement equipment I am using at present and I don't really know anything about them except the notations on their packages.
RobHid
Jan 30, 2023
3
Hi, Harald Kapp,
thanks for your answer, but I'm not sure it is the right one.
I found that datasheet (stand-up miniature power resistors by BC Components) on alldatasheet.com before posting my thread and it doesn't match with my resistors for the following reasons:
1) resistors of the series SMW02 only range from 0.1 to 200 ohm whereas mine have a nominal value of 600 ohm;
2) resistors of the series SMW02 have 4.5 mm long leads whereas mine have much longer leads (around 2 cm).
In addition, my resistors are employed as a 300 ohm shunt resistance in a 4-20 mA corrent loop, so they don't need to be miniature power resistors.
Martaine2005
May 12, 2015
5,318
Have a search for metal foil precision resistor. Vishay have 400R and 500R so it must be there somewhere.
Martin
kellys_eye
Jun 25, 2010
6,512
Given the profundity of exact values and even better tolerances that are available, do you need to have the exact device as a replacement? Isn't the right value/tolerance good enough regardless of its 'shape'?
