Looking for Power Switch - Optonica Amplifier SM-1515B
EADGBE
I am curious -- What's wrong with the switch?
It's such a simple component. Are the internal contacts burned or
worn?
Eeyore
worn?
Most likely. As the contacts are not replaceable you need to find an
exact replacement and there lies the trouble.
Graham
I
Ian Jackson
Graham
Need it be and 'exact' replacement? Maybe it's time for a bit of
creativity and improvisation?
EADGBE
Would any SPST switch with an adequate voltage/current rating suffice
(presuming it fits where the old one did)?
Eeyore
Aside from the detail of fitting in the same hole, absolutely yes. Do
ensure you get a type suitable for *mains* switching.
Graham
F
FJ
Graham
Another viewpoint: Just permanently connect the wires (and apply proper
insulation), and switch the amp on and off with a correctly rated switch in
the mains lead.
Or, maybe even better, leave the amp powered-on.
The hole of the original switch can be filled either with the now
non-functional switch, or a nice power-on indicator. Add some creativity
here ;-)
YMMV, Folkert/NL
James Sweet
in the mains lead.
here ;-)
YMMV, Folkert/NL
That's ghetto, much better to fix it right, you might be able to disassemble
the switch and repair the contacts.
Why would it be better to leave the amp on all the time wasting energy? That
stuff isn't free.
JohnC
I appreciate the comments and suggestions.
The switch that needs replacement is actually fine electronically. In fact
it is always on. The problem is with the snap action mechanism. The switch
lever took a blow to the side and broke some key plastic rocker parts that
allow the snap action to function. Any SPST switch rated at 120V, 1 amp?
will work but my preference is to maintain the cosmetics. Switch should be
OFF in the down position and ON in the horizontal. I thought this flat lever
switch was fairly common but perhaps I was mistaken.
I viewed some of the recommended sites but came up negative.
John C.
