Looking for small DMX player / recorder
erwinredl
Sep 12, 2022
10
Hi there,
I am looking for small DMX player/recorder, preferably just a circuit board with screw terminals, and no housing. In the past I've used the Chauvet DJ DMX-RT and removed the housing but the quality of that product declined dramatically to a point where it is rendered useless. Same with NicolAudie products, too expensive for my application, very buggy software, and unreliable hardware for professional use.
I've looked into the Enttec S-Play SP1-1 70092 but it is simply too big and expensive for my application. Raspberry PI, etc. would also be too big and bloated for my very, very basic needs.
I've found 2 products on DMX4all.de in Germany, the DMX-Player XS and the DMX-Player L-MK2, but just the shipping is $70+.
Application:
- Program light sequences created with the ETC Mosaic MSC / Mosaic Designer 2 software / hardware (my favorite DMX toy but too big and too expensive for my application)
- Record DMX/ArtNet/or similar light sequences from ETC device to small DMX player/recorder hardware
- Play the light sequences back as DMX data on start-up of small DMX player/recorder
No calendar function or reordering of sequences needed, just the most basic record and looped playback.
Any recommendations?
Thank you for your help in advance!
Erwin
GlennP
Jan 12, 2023
erwinredl
Sep 12, 2022
10
Hi Glenn,
Thank you for your reply. I've worked with the LanBox in the past and always have been satisfied 100%. Unfortunately it is too big. My product is basically something that mimics a painting but done with LEDs. The DMX player would be built into the painting's frame.
I've done this in the past by taking out the circuit boards of the Chauvet DJ RT and de-soldering the XLR connectors. The Chauvet also is pretty affordable. Unfortunately their quality is no longer acceptable. The Chauvet's SD card reader is totally unreliable, skips data, etc. Since I've used probably 50+ of their units in the past they've sent me several replacements but all of them now have the same SD card reader problem independent of what SD card I use. Anyway...
The LanBox or a Raspberry are too large and overkill because all I'd need is recording and playing back a DMX stream reliably.
The DMX4All product line of player/recorders seem ideal but shipping from Germany is $70.
DMX4ALL:
https://shop.dmx4all.de/de/dmx-player-xs.html
https://shop.dmx4all.de/de/dmx-player-l-mk2.html
Cheers,
Erwin
