Looking for two-input comparator with hysteresis
Pooh Bear
Christopher said:
I'm concerned about connecting the lower power rail back to the
transformer winding - surely they won't be at the same voltage because
of the rectifier voltage drop?
You could go half wave and connect the CT to ground. That'll need a CT 24V sec
though.
In this case just take the ac signal to the schmitt from either end of the TX.
It'll aproximate a square wave at line frequency now.
Graham
Pooh Bear
Christopher said:
Thanks Spehro. I think I see what you're saying, though I still need to
have a think to convince myself as to why a resistor is needed at both
ends of the transformer winding.
Only one resistor in series ( as part of the PD ) is needed between the schmitt
input and the transformer connection. Since the voltage now aonly goes about 1V
below ground and with the potential divider helping you also won't need a series
diode.
Graham
Pooh Bear
Christopher said:
I've thought about this a bit more. If you connect the "top" end of the
transformer winding to the Schmitt trigger input through a 100k ohm
resistor, then connect the Schmitt trigger input to logic ground through
a 22 nF capacitor, you form a potential divider which also acts as a low
pass filter. Presumably you are suggesting connecting the logic ground
to the "bottom" end of the transformer winding through a 10k ohm
resistor
No. No additional connection is required. The power supply provides the return
part of the siganl path.
Graham
Pooh Bear
Christopher said:
Thanks for the very useful advice. I'm looking for something simple
which just works reliably, and this seems to fit the bill. If I've done
my calculations right a potential divider consisting of a 100k ohm
resistor and 22 nF capacitor
An R and a cap are a filter not a PD.
gives a maximum voltage of around 10 V
between the Schmitt trigger input and logic ground (for a 50 Hz signal).
And the schmitt is running of how many volts ? 5 ? The job of the PD is to reduce
that 10V to a voltage within the supply rails of the schmitt.
Actually, yout 12V ac winding will produce about 17V pk-pk so a PD of just
greater than 3:1 should be used. Make that 100k into 330k and add a 100k from
schmitt input to ground in parallel with the 22n ( this won't alter the RC time
constant very much ).
Are the 100 k ohm and 22 nF standard values,
Yes.
or did you and John
calculate them specially?
No.
Should I connect another resistor between
logic ground and the "bottom" node of the bridge rectifier?
No. Not required.
Graham
Pooh Bear
Christopher said:
The clock hands move once per minute. I would consider a 5 minute error
in 6 months to be acceptable accuracy, and from what I know the UK power
grid should be capable of providing this.
It's actually way more accurate than that. Remember that mechanically driven
clocks with ac synchronous motors have to keep time too.
Graham
Pooh Bear
Don said:
And the problem with a CMOS schmidt trigger is...?
Now only the other week I asked if it's Schmitt or Shmitt and now you say
Schmidt ! Come on which one is it now ?
Graham
Pooh Bear
John said:
OK, why not? I's been a couple of decades since people figured out
CMOS latchup and took suitable precautions. Modern HC parts are spec'd
to handle numbers like 50 mA without problems.
I still don't feel quite right doing it though. And for just *one resistor*
extra.
Graham
Jim Thompson
And the UK tendency to prefer to overdesign too.
Graham
Yep. Why use a 4x4 post when you have a Greek column handy ;-)
...Jim Thompson
Pooh Bear
Jim said:
I NEVER rely on ESD diodes for clamping... VERY BAD engineering
practice.
...Jim Thompson
I'm pleased to see I'm in rarefied company ! It's just so *cheap* doing that
too. ;-)
Graham
Pooh Bear
Jim said:
Hard to predict... but it'll be brand dependent. ESD structures are a
black art and are different for every foundry.
Exactly so. Unless a component has manufacturer specced data I'd avoid using it.
Why don't you try it and report back (and specify brand of 'HC14)?
The cost of which will be what ? vs 0.1c for a resistor in qty adding $1 total
BOM cost to a run of 1k pcs.
Graham
Pooh Bear
Christopher said:
They divide potential, don't they?
On a frequency dependent basis ! It's called a filter !
I advise you not to get into the habit of using incorrect terms. It could prove
expensive in the long run and simply daft in the meantime.
The way they divide potential changes
with frequency, making them a filter, but I would argue that they're a
potential divider too.
No. A PD is quite specifically something else.
Graham
Pooh Bear
Christopher said:
According to Wikipedia the inventor's name was Otto H. Schmitt.
That accords with the last info posted on the subject here too.
Ta, Graham
Christopher Tidy
Pooh said:
They divide potential, don't they? The way they divide potential changes
Chris
Christopher Tidy
Chris
Christopher Tidy
That's interesting. So two capacitors in series would be a potential
divider, because the division of potential isn't frequency dependent?
Chris
John Larkin
Well, they usually do. TI specs +-20 mA for its HC14, with no
footnotes about duration.
John
Pooh Bear
Yes, that can indeed be done. It has another useful property. Capacitors don't
dissipate energy so it's effectively lossless unlike a resistive divider.
Graham
