Looking to identify an unknown electronic component...
W
Webtheorem
Hi Everyone,
I have an unknown electronics part, and I'm looking to identify it:
- 5 pin device, something variable about it b/c there's a slotted screw
turn on top
- Markings:
- TOP: N3 4
- SIDE: TRO 215 E572
- Image: http://www40.brinkster.com/electromagnetic/images/part.jpg
If someone has an idea what it could be, then I could set it up as
though it were said device, and check if behaves as expected. I just
don't have any clue where to begin as of yet.
Thanks for any help!
Adrian
Hi
Hi Everyone,
turn on top
- Markings:
- TOP: N3 4
Looks like a small coil (=inductor) - the type of thing you'd find in
the radio frequency stages of.... a radio <g>
Can't help on the meaning of the markings - it'll be a part number of
some sort, and without knowing the manufacturer it's hard to make any
suggestions.
As to testing it - these things typically have two coils, possibly
with a capacitor across them, making a tuned circuit.
Check with an ohmmeter across the outer two pins of the 3-in-line -
probably get continuity - low ohms. Also check the other coil (the two
opposite pins).
The screw adjustment in the top will screw a ferrite core down into
the coil to allow it to be fine-tuned...
Hope this helps
Adrian - Suffolk UK
I
ian field
Webtheorem said:
Hi Everyone,
turn on top
- Markings:
- TOP: N3 4
It looks as if the manufacturers name is stamped around the adjustment
hole - do a google search!
