Low-Cost Bluetooth Modules
Jerry Girard
I'm looking for some low-cost Bluetooth modules for the ability to easily
add Bluetooth capability to some of my designs. I suppose something under
$20 would be acceptable. I need the module to be self contained--just
solder onto the board and communicate to it with a micro. I module that
manages itself would also be desirable. A SPI or I2C type interface would
be preferred.
Does anyone have and leads or sources for something like this? Thanks.
John_H
be preferred.
Google: bluetooth serial module
and you get what I saw last week while hunting down parts...
http://www.national.com/pf/LM/LMX9820A.html
Meindert Sprang
Well, if you can solder BGA.....
Be aware though that these tranceivers are not complete bluetooth modules
and certified as end-product. Which means that your design is not FCC
approved by default. If you use a module from Ezurio (www.ezurio.com, former
TDK) your product is FCC approved for the BT part because these modules are
approved as end-product and come with a sticker you stick on the outside of
your product to comply with the rules.
Meindert
PeteS
Meindert
I use the Ezurio module, and something else you get with a completely
pre-approved module is the right to use the Bluetooth symbol. If you do
your own implementation, and you want to use the Bluetooth symbol,
you'll need to go through the approvals process (about $10k). If you
don't need the symbol, then it depends what you need - Gennum
(http://www.gennum.com/) makes a module as well.
Cheers
PeteS
