Low-Cost High-Speed master-slave supported Bluetooth Module TS-M1035
Status
Not open for further replies.
Aaron-Tecksay
Apr 26, 2024
22
The TS-M1035 is a high-speed BLE 5.1 Bluetooth module that supports serial port transparent transmission, master-slave mode, and AT commands. Users can easily modify parameters such as serial port baud rates and device names using the provided AT commands, offering flexible and straightforward operation. This module boasts excellent stability, ultra-low cost, and high reception sensitivity. It is available with either a built-in or an external antenna option, catering to various project needs.
Model No.: TS-M1035
Bluetooth Version: BLE 5.1
Frequency Band: 2.402GHz-2.480GHz ISM band
TX Power: -20dBm~+10Bm
Receive Sensitivity: -95dBm
Air Rate: 250Kbps/1Mbps/2Mbps
Antenna: PCB Onboard / IPEX Antenna
Advise Range: 80m
Memory: 48KB RAM
Pin/GPIO: 16/12
Power Supply: 2.5~4.3V
Operating Temperature: -40℃~+105℃
Peripheral Interface: UART/SPI/I2C/ADC
Serial Transparent Transmission Rate: BLE 20KB/s
Applications
Smart home
Location tracking
Bluetooth electronic scale
Intelligent educational equipment
Vehicle testing equipment
Measurement and monitoring system
Bluetooth wireless data transmission
Industrial sensors and controls
Medical equipment monitoring and wireless control
buymode1
Jun 15, 2024
7
Thank you so much for sharing the details of the TS-M1035 Bluetooth Module! The information you provided is incredibly helpful, and I appreciate the effort you put into breaking down the features and applications. This will be a great addition to many projects. Thanks again! 😊
Aaron-Tecksay
Apr 26, 2024
22
if this module is suitable to your project, you can get some samples for testing first  😄
buymode1
Jun 15, 2024
7
Thank you for the kind offer! I don't need any extra modules for my projects right now, but if I need something, I'll let you know ASAP. Thanks, buddy! 😊
Status
