low hum on Realistic receiver
buddy
I just acquired an old Realistic STA-45B stereo receiver. It works
fine except that it produces a low hum to the speakers as soon as it is
turned on. It does not get louder as the volume is turned up. It is
also in the headphones.
The hum occurs even if no inputs are connected, just the speakers or
headphones. I took the cover off and sprayed everything with
electrical contact cleaner. All screws from boards to chassis were
tight.
It is annoying but if I can't fix it I will use it like this if I must.
I only want to use it to go from my computer's soundcard to the Aux
inputs, to use stereo speakers instead of PC speakers. I do home
recording and need better sound to mix/master.
I do not have any experience to diagnose/repair audio equipment, but a
little long-ago experience testing components on computer boards. I
have a multimeter.
Can someone describe what to do to track down the problem?
Arfa Daily
tight.
have a multimeter.
The problem here is almost certainly the main smoothing capacitor. This will
be the biggest electrolytic capacitor in the unit. Value will be 1000 or
2200 or 4700uF or something similar. Replace with similar value and voltage
rating, and there's a 95% chance that the hum will go away.
Arfa
K
Ken
tight.
have a multimeter.
As Arfa said, it is almost certainly an electrolytic cap. This is a
situation where an ESR meter would be helpful. In fact, I had a
receiver that developed the same type of problem and found it in minutes
by using an ESR meter. Just one problem found could pay for the meter
in time saved.
Asimov
"buddy" bravely wrote to "All" (14 Jan 06 23:10:07)
--- on the heady topic of "low hum on Realistic receiver"
bu> From: "buddy" <[email protected]>
bu> Xref: core-easynews sci.electronics.repair:355180
bu> I just acquired an old Realistic STA-45B stereo receiver. It works
bu> fine except that it produces a low hum to the speakers as soon as it
bu> is turned on. It does not get louder as the volume is turned up. It is
bu> also in the headphones.
bu> The hum occurs even if no inputs are connected, just the speakers or
bu> headphones. I took the cover off and sprayed everything with
bu> electrical contact cleaner. All screws from boards to chassis were
bu> tight.
bu> It is annoying but if I can't fix it I will use it like this if I
bu> must. I only want to use it to go from my computer's soundcard to the
bu> Aux inputs, to use stereo speakers instead of PC speakers. I do home
bu> recording and need better sound to mix/master.
bu> I do not have any experience to diagnose/repair audio equipment, but a
bu> little long-ago experience testing components on computer boards. I
bu> have a multimeter.
bu> Can someone describe what to do to track down the problem?
There might be an open rectifier but if the rectifier isn't discrete
then test the bridge rectifier. However, given the age of the
equipment, it is more likely to be a problem with dry electrolytic
supply filters. Test all electros with an ESR meter. (beg, borrow, but
don't steal!)
A*s*i*m*o*v
.... A stereo system is the altar to the god of music.
Ac hum in an audio device is very easy to find with an o'scope. It is
obvious which filter capacitor is not doing its job when looking at it
with the o'scope. It is also possible that a power supply bypass
filter near the audio circuit is also weak and will also be easy to
find in this way.
Sam Goldwasser
tight.
have a multimeter.
In addition to the main large filter capacitors, also look for any
other power supplies that might have bad caps. I found a small
capacitor that was high-ESR in a Reaslitic STA-20.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
JANA
Change the main filter capacitors, and most likely the hum will be fixed.
JANA
_____
tight.
have a multimeter.
buddy
Thanks to all who replied, and "southmetro" who emailed. Sounds like
the first thing I should try is:
Replace main "smoothing" "large filter" capacitors.
So I googled to get an idea what they look like. I saw photos of the
small "M&M" ones, and the cans. I assume I am looking for the cans.
Could someone help me identify the ones to replace?
Please download these 2 photos:
www.idcomm.com/personal/buddyboy/realistic-sta-45b-top.jpg
www.idcomm.com/personal/buddyboy/realistic-sta-45b-bottom.jpg
In the "top" photo, there are 2 large cans next to each other, in the
middle of the board at the top of the photo (which is rear of the
receiver). They are lavendar color, and say
1000 uF 25 V
CE
1 9.
In the "bottom" photo, there is a small board in the top of the photo,
just left of center. The board says "AC Input". The cans are:
(lavendar one)
CE (W)
1000 uF 35 V
looks like it has some kind of glue on the bottom in addition to being
soldered
(silver one)
+ Nippon Chemi-Com
+ CE W
+ 35 V 470 uF
which are the one(s) to replace?
Questions:
-To replace, should I :
1. clip leads, leaving about 1/8 " nub to solder new one to (seems to
me this is easiest way) or
2. unscrew the board and unsolder where the lead comes through the
board on the other side
- do I need to do anything to "discharge" them first? leave unplugged
for some amount of time, or something else?
- unrelated question - there is no light for the FM scale and
indicator. Is this the way the receiver was made? In the "top" photo
you can see the bulbs for the two meters, but I don't see anything to
light the FM scale and indicator. Hard to believe it was made this
way. But no biggie, as I said in my OP I only want to use the Aux
input.
Rod
Arfa Daily
1000 uF 25 V
CE
1 9.
(lavendar one)
CE (W)
1000 uF 35 V
soldered
(silver one)
+ Nippon Chemi-Com
+ CE W
+ 35 V 470 uF
Questions:
input.
Rod
I would go for the big grey one in the middle of the underside photo first.
This would appear to be the main smoothing block. The board at the back left
on the topside photo, looks like it is part of the output stages. The pair
of axial caps in the middle of that board may be supply rail decouplers or
output caps. Likewise the pair of radials at either end. These caps are much
less likely to be the cause of the problem than the grey one.
If you can get access to a 'scope, or have a buddy with one, I would feel
inclined to have a look at the ripple levels on the grey cap. It looks as
though it may be a ' dual ' type having 3 tags. One is usually common
negative, whilst the other two are the positives of two different caps in
the one can. They may or may not be both the same value, but are usually the
same working voltage - ie could be 2200uF + 2200uF @ 35v, but could also be
2200uF + 1000uF @ 35v.
If you do finish up replacing the wire ended caps, they should be replaced '
properly ' that is by removing the old one from the board, clearing the
holes, and resoldering the new caps' wires directly back to the print.
Leaving a cut end from the old one, and trying to tack solder the new one is
going to give you problems with the original solder crystallising as it
melts when you try to solder the new wire. As far as I can see, both sides
of all the boards are get-at-able, without having to unscrew them. Or am I
missing something in what you're asking ?
Arfa
buddy
No, that is what I was asking. But I realized that it's fairly easy to
do the "right" way. I replaced the two caps in the Input board in the
"bottom" photo before I saw your post, but no change.
After I saw your post I removed the big gray one - had to drill out the
screw $%& for the clamp - it was just a regular one, 2000 uF and 50 V.
I replaced it, but still no change.
I think I'm at the limit of what I can do with no test equipment so
I'll have to use it as-is for now.
I really like the look of the old Realistic with machined Alum knobs
and brushed Alum faceplate and solid wood case. The sound is very
"clean".
Reminds me of a separate tuner/amp combo from Technics I had in the
70's.
Thanks for trying,
Rod
Asimov
"buddy" bravely wrote to "All" (17 Jan 06 13:55:16)
--- on the heady topic of "Re: low hum on Realistic receiver"
bu> Xref: core-easynews sci.electronics.repair:355552
bu> I really like the look of the old Realistic with machined Alum knobs
bu> and brushed Alum faceplate and solid wood case. The sound is very
bu> "clean".
bu> Reminds me of a separate tuner/amp combo from Technics I had in the
bu> 70's.
bu> Thanks for trying,
bu> Rod
IIRC Realistic were likely re-branded Sharp. You will find that
styling and look in Sharp components of the same period.
A*s*i*m*o*v
.... When I was your age, we carved transistors out of wood.
Arfa Daily
bu> "clean".
bu> 70's.
bu> Rod
A*s*i*m*o*v
Transistors !! Wood !! ??
We had to make tubes out of old jamjars and paper clips, all whilst we lived
in a cardboard box in the middle of the highway, watching the snow come in
through the open top. Sounds to me like you had it easy ...
Arfa
Michael Ware
IIRC Realistic were
A*s*i*m*o*v
Tape decks, yes. Receivers were made to RS specs by unknown factories.
jakdedert
Michael said:
IIRC Realistic were
Some of the mid-70's ones were identical to Hitachi models....
jak
