Low Jitter 20MHz oscillator
Jitter is a function of the phase noise profile.
Set your jitter spec., calculate your jitter from the phase noise
of your chosen oscillator.
Then you don't need to argue with anybody.
It's not difficult.
At what kind of offsets from the carrier should the phase noise
profile be measured, to give meaningful jitter characteristic ?
At least for measuring phase noise for oscillators for RF applications
(especially first LO), it is very hard to get meaningfully readings
within +/-1 kHz from carrier, even with high quality test equipment,
unless you use some deep crystal notch filters at the carrier
frequency.
Jeroen Belleman
It's not difficult.
Well, this begs the question: How do you do it?
Jeroen Belleman
Or begs (for) the question, which is a common use.
John Larkin Highland Technology, Inc
jlarkin at highlandtechnology dot com
http://www.highlandtechnology.com
Precision electronic instrumentation
Picosecond-resolution Digital Delay and Pulse generators
Custom laser drivers and controllers
Photonics and fiberoptic TTL data links
VME thermocouple, LVDT, synchro acquisition and simulation
The concept is pretty straight forward;
take the single sided spectral noise power and
convert it total rms jitter.
Where’s it used, think about it for a second;
What is one of the primary concerns when you
apply a clk to any high performance digitizer?
What’s on the back end of any modern day acquisition system?
Jeroen
That's not an answer! You'll have to come up with something a little
more explicit!
Jeroen Belleman
