Low voltage cut in/cut out
Palmer Pease
Sep 26, 2017
5
Greetings all, first post. I did a search to no avail.
I would like to build a circuit that will close (or open) contacts when input voltage falls below a specified value. It will need to be quite precise, within a tenth of a volt DC or less. In the 2-2.5 volt range.
Here's the project. I would like to convert my '04 GMC to electric cooling fans for the radiator/AC condenser/transmission cooler. The engine and transmission temp sensors are provided a 5v reference. When the sensors are cold the resistance is low so the return voltage is relatively high. As the fluid increases in temperature the resistance increases and the voltage drops. When the voltage drops to a specific value, I need to start triggering fans on. Most E Fan setups are two, two speed fans. I plan on four or five temperature/voltage trigger points to manage noise and electrical usage, plus provide a bit of redundancy.
Wiring the relays to control the fans is the easy part for me. Reading wiring diagrams and schematics is easy. Soldering circuit boards, resistors, diodes, relays, I'm good with all of that. Capacitors I understand but don't know the math to size them. I should have paid more attention to transistors. But I'm good with logic these days as opposed to my teens when I did the Heathkit DC electronics course
Any suggestions?
Tha fios agaibh
Aug 11, 2014
2,253
You could make a comparator circuit fed with a Voltage divider input and a transistor to drive a relay for your fans but why not do it the simple way;
Thermal switch to relay to drive fans?
If you need to manage noise, why not consider suppression
Tha fios agaibh
Aug 11, 2014
2,253
Instead of 4 or 5 trigger points, why not go right to a Pwm circuit that'd send a varying output right to the fans?
Palmer Pease
Sep 26, 2017
5
Managing with thermal sensors would require adding thermal sensors. A couple of issues. There's no simple place to add an engine coolant sensor, adding a trans temp sensor would require welding a bung in the pan which is succeptible to damage.
In addition, I would like to use the current voltage outputs of the factory system, keeping my add on very stealth.
As for noise, I'm simply talking audible noise of pulling two high volume fans on high at once when that is rarely required. The only time I would need that is when the AC is on and vehicle sped is zero.
Alec_t
Jul 7, 2015
3,821
How are you proposing to control the speed of the fans if you don't use PWM?
Alec_t
Jul 7, 2015
3,821
Then I don't see how the TS proposes to use all the trigger points :
["I plan on four or five temperature/voltage trigger points to manage noise and electrical usage"]
Palmer Pease
Sep 26, 2017
5
As the temp increases, the voltage will continue to drop and I will need more cooling.
So maybe the first fan comes on at 2.5v
Second at 2.4v
Third at 2.3v
Fourth at 2.2v
duke37
Jan 9, 2011
5,364
Look at the LM3914 bar graph driver circuit, this has ten outputs and will add outputs as the voltage rises.
You will need output driver circuits for each fan and an input circuit to give the required range.
AnalogKid
Jun 10, 2015
3,056
Two fans with 3 states each (off, half, full) equals 9 combinatorial states. Use an LM339 or LM3914 to create 5 ascending states, and diodes to matrix them to any of the 9 possible fan states. For example:
Sensor Fan 1 Fan 2
State State State
0 off off
1 1/2 off
2 1/2 1/2
3 1/2 full
4 full full
Those are supposed to be three columns, but the site deletes the spaces.
ak
duke37
Jan 9, 2011
5,364
Depending on the way of dropping the fan speed by half, it may need four relays with drivers and some logic. If the fans just use resistors to drop the voltage and so the speed, then I would favour putting both fans on full speed and controlling the speed with a pulse width modulator to drop the voltage as has been suggested. (#4)
It would not have steps in the control but be continuously variable from off to maximum.
I would think that both fans running gently would be quieter than one going fast and the other doing little.
AnalogKid
Jun 10, 2015
3,056
I agree. That's why my example increments total fan power in evenly spaced 1/2 fan steps. Notice that for the "1 full fan" condition I have two fans running at 1/2 power each.
ak
AnalogKid
Jun 10, 2015
3,056
It is not clear what the signal source impedance is. It sounds like a constant voltage with a varying resistance in series. More clarity is needed, but based on that assumption:
1 - LM324
4 - 1N914 diode (routing)
4 - power MOSFET
4 - 1N4004 diode (protection)
1 - voltage regulator (optional)
$10-$15, no programming, no 555, no PIC, no generated EMI.
ak
Alec_t
Jul 7, 2015
3,821
:confused: You said (post #1) that the signal is 2.5V dropping to 2V.
