Low voltage drop diode
ivak245
Jun 11, 2021
144
Is there a diode which has a lower voltage drop than the standard 0.5v for a silicon unit, but I need something which can handle up to 10 amps. The germanium type were less, but I don't think there were large power ones made, only small signal type.
Martaine2005
May 12, 2015
5,318
There are Schottky diodes that are approx 0.2 - 0.3V and 10A rated.
They are quite common for solar panels.
Martin
crutschow
May 7, 2021
991
What will you use the diode for?
For certain applications MOSFETs can be used as diodes with very low forward drop, equal to the current times their on-resistance.
AnalogKid
Jun 10, 2015
3,058
To Wally's point, Linear Technology (now a part of Analog Devices) makes controller chips that turn a power MOSFET into a very low Vf diode. More complex and expensive than a big-ass Schottky diode, but 2x-10x more efficient.
ak
Alec_t
Jul 7, 2015
3,821
Other manufacturers offer similar things. Google "ideal diode".
ivak245
Jun 11, 2021
144
I am using it for a solar panel. I found some MBR20100CT's locally. This is a 2 diode package, and rated at 20A ,so should do the job.
Martaine2005
May 12, 2015
5,318
That’s a dual diode package that each diode is rated for 10A MAX.
Martin
AnalogKid
Jun 10, 2015
3,058
The two diodes thermally track very well. It is safe to combine them in parallel for a max total current of 15 A.
ak
