Low voltage Relay
mbyamukama
Apr 5, 2011
8
Hello all. I am working on an circuit in which I require a switch to arm if the voltage between the terminals of the load is less than -200mV (e.g, switch is armed if V=-400mV but disarms if V=-100mV) so that I can send current to the load from a battery source. I am thinking that a relay with such low specs would but an not sure where to look. any help will be really appreciated. :)
poor mystic
Apr 8, 2011
1,106
Hi mbyamukama
I suggest analog comparators (not op-amps wired as comparators) to drive logic and a power transistor at the output of the logic to drive an ordinary relay.
