D from BC
- Jan 1, 1970
- 0
I'm currently searching the net for the lowest supply current op amp
with a GBW of >= 5Mhz.
Other specs required:
Vs >=5V
Output drive current: >0.5mA
Offset V: <100mV
Noise: to be compared
Slew: >0.3V/uS
Dual preferred but single ok.
Input includes ground.
Output can be rail to rail, but not required.
Av >30dB
Single supply operation
So far I've found: (Comparing @ Vs=5V, 25C)
Linear Technology LT1492: Is = 550uA
Intersil EL5220: Is = 500uA
Analog Devices AD8631: Is = 300uA
Maxim MAX4249-MAX4257: Is = 420uA
Texas Instruments TLE2161: Is = 280uA LMV822: Is = 300uA
Please note: It's possible I missed something in the data sheets and
I'm comparing without the same conditions.
Anybody know similar op amps I can check out? Or is that the ballpark
and it's best that I chose from the above?
D from BC
Vs >=5V
Offset V: <100mV
Slew: >0.3V/uS
Av >30dB
D from BC
