LT Spice error Messages
kk1067895
Feb 27, 2020
This is the error message, how I can fix it.
WARNING: Node NC_01 is floating.
WARNING: Node NC_02 is floating.
WARNING: Node NC_03 is floating.
WARNING: Node NC_04 is floating.
WARNING: Less than two connections to node NC_01. This node is used by M1.
WARNING: Less than two connections to node NC_02. This node is used by M2.
WARNING: Less than two connections to node NC_03. This node is used by M3.
WARNING: Less than two connections to node NC_04. This node is used by M4.
Warning: Pd = 0 is less than W.
Warning: Ps = 0 is less than W.
No AC stimulus found:
Set the value of a current or voltage source to "AC 1."
to make it behave as a signal generator for AC analysis.
Direct Newton iteration for .op point succeeded.
Date: Thu Feb 27 12:42:34 2020
Total elapsed time: 0.188 seconds.
tnom = 27
temp = 27
method = trap
totiter = 25
traniter = 0
tranpoints = 0
accept = 0
rejected = 0
matrix size = 14
fillins = 10
solver = Normal
Matrix Compiler1: 73 opcodes
Matrix Compiler2: 1.39 KB object code size
  • Integrated.asc
HarryA
Jan 22, 2017
90
Using a generic NMOS for NMOS_035
error on 5827_035.lib missing.
14,315
When commenting the .lib statement the above error dissapears.
The error messages with reference to floating nodes you show indicate an error in the model of the MOSFET in that library.
Unfortunately we cannot simulate as we do not have the library you're referencing in the schematic.
The error message "no ac stimulus found" is due to missing AC values for V2 and V3.
