LT1787 current monitor when low voltage?
daGenie
Jan 23, 2012
43
The buffer there helps to isolate the output of the lt1787 and the input of the ltc1404. Due to the high impedance of a buffer, the amount of current needed to drive the input is relatively small and therefore can monitor very small changes in its input. If you consider it using Ohm's law, a very high value of R with a very small changes in the value of I would produce a very large change in the value of V. (V = IR).
Without the buffer, the output of the lt1787 would depend on the input impedance of the next stage that it tries to drive.
