Magnavox 2SB700-7562 R420 value
Guest
Hi all. Am checking this for another shop who has not the internet. Magnavox
model TS2554C107 Chas # 2SB700-7562 Resistor R420 Need the value.
Anyone have it?
Cheers, Danny
Sofie
Danny:
If this this the resistor that is connected to the GATE of the power mosfet
through L422 then the resistor value is 2K.... or that is what I recall.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
Ray
Service manual parts list has R420 at a value of 1.0 Ohm, 5%, 1/3W, Metal
Film - P/N 483511657109
David
On one of the vertical output ic B+ lines. He needs to make sure the
vertical ic circuit bulletin is followed for a proper repair. There
is a change of the Philips part numbers for the B+ and B- diodes and
resistors and a modification to secure the metal bar being used as a
heatsink to the vertical ic to prevent the expansion from breaking the
pins of hte vertical ic loose again.
David
