MagneTek Series 6400, Model 6415, Power Converter
Richard Gentry
Sep 11, 2015
3
I recently bought a 1995 Shadow Cruiser Truck Camper equipped with this power converter. I have two questions for now.
1) Will this converter charge the 12 volt battery when plugged into AC power?
2) What can I expect this power converter to do?
Thank you!
Sincerely,
Rich Gentry
Martaine2005
May 12, 2015
5,318
Here is the schematic for your converter:
http://www.parallaxpower.com/6400_6600/6400schematic.pdf
The manual:
http://www.parallaxpower.com/6400_6600/6400 owner operator guide.pdf
There should be at least 1 fuse. Not sure how they are installed. Either in a square fuseholder you push in to pop out or possibly a round holder you turn to remove.
See if this helps. If you need more assistance just ask.
Good luck
That whole section was copied from HERE.
Except the friggin' links don't work.......:oops:
Martin
Richard Gentry
Sep 11, 2015
3
Thank you Martin for getting back to me. Will the converter charge the RV battery when the camper is hooked up to electric?
Martaine2005
May 12, 2015
5,318
There is nothing to stop you running a charger from the converter while on AC.
Martin
