Making your own parts on eaglecad and using I2C
Guest
Hi Everyone, im doing a project and need some advice if thats ok
Im designing a PCB on eaglecad and need to use a 28pin header. The header with the correct pitch is only 26 pin or 32 pin. How can I redesign the part so that it has a 28 pin header in the library? Is it a difficult and complicated processs?
Secondly, I will be interfacing a beagle board with an LCD so if anyone is able to provide me with some info on how to program that in c and how to use I2C it'd be great
thanks for the help, all the best
Johnsteave7
First it is based upon you how much idea you may gathered by pcb. Then you try to eradicate your project problem. If you have no preference I would recommend CADSoft Eagle. Its free, easy and you can get several tutorials. Others may recommend other CAD software.PCB is a well and good, there are plenty of places more expensive than your service too! I’m not recommending but perhaps you could check out this ]http://actpcb.com/pcb-calculator] link.
Thanks!!!!
