N
N_Cook
- Jan 1, 1970
- 0
Early and bad PbF but is it the problem here, most of the ECC83 socket
solderings were very iffy .
Volume dropped and owner changed the valves. Volume came up but a distortion
on the overdrive channels emerged soon after. Redoing those socket
solderings and usual suspects on front controls board has not cured the
distortion problem.
schematic on elektrotanya
Harsh cut-off more like clipping and no sign of any smooth saturation,
rounding of the peak/s, just launches into cut off on the peaks (not
troughs). With all pots at mid posistion the signals ,clean and OD, are
sinusoidal and amplitude ratio of about 2:1 OD:Clean in the gain and tone
block. That preceeds the valve V7 which with mid pots and order 10mV amp
input 400 Hz has on pin2 , grid, about 100mV pk-pk for clean but 7 volt on
OD thence clipping.
All valves test fine, all R in relevant area are fine. A cap problem ? but
coinciding with valve changing? I've not inspected underside of that
wired-in board but I'm assuming a cap PbF solder problem. Vol drop could
even be the bad PbF at the input socket but problems appearing /
disappearing at "intimate" handling suggest PbF problems. There is loads of
relays in this design also .
distortion problem.
OD thence clipping.
