Massage Chair Remote Error(King Kong)
Zdenek668
Nov 29, 2021
5
Figured out I had to reduce the size to upload a photo but here is the only transformer I can find on my chair…
Shredder
Aug 3, 2020
14
I’ll need some decent pics of tge board in case the thermistor is there. Most transformers like that do not have built-in overloads
Zdenek668
Nov 29, 2021
5
Is this good enough or do you need a different angle to identify the thermistor. What should I be looking for to get a better picture of?
Shredder
Aug 3, 2020
14
I don’t see one there….is that the whole board for the chair or just the power supply board? Seems small. Have you looked for any fuses soldered directly to the board(s)?
Shredder
Aug 3, 2020
14
I suggest you check the transformer first and make sure it is functional. There are no fuses on this board; is there a fuse somewhere on power input side of transformer? I do not see anything burned or abnormal here.
Zdenek668
Nov 29, 2021
5
this is the only other board and it does have a glass fuse soldered to it but the continuity checks out ok. The only other fuse is a removable one pn the power cord and it was ok as well. I’ll try testing the transformer but all I have is a DVM. I guess I can check it to make sure it’s not shorted out but how do I test it to make sure it doesn’t have a open winding? I don’t see any burned windings or any burned insulation smell.
Shredder
Aug 3, 2020
14
Well, I’d apply power (120vac) to the transformer primary and insure each pair of secondary gives a voltage output. If I recall correctly, my chair had two sets of outputs. It looks like on yours that you should get 24vac on each set.
Shredder
Aug 3, 2020
14
Just leave the primary attached as normally and unhook the two sets of orange outputs and check their outputs….just make sure you put everything back the same.
Shredder
Aug 3, 2020
14
If one winding is toast, then I’d suggest buying another 120v to 24v transformer at or above rated current and parallel their primaries.
Shredder
Aug 3, 2020
14
Looks like that thing puts out about 5 amps on each secondary winding
73's de Edd
Aug 21, 2015
3,730
Sir Zdenek668 . . . . .
QUESTION . . . . . . is there any sign of power presence on any part of the chair, by any activity or LED indicators or display ?
ANSWER ?
Viewing the transformer we can expect the two paired sets of windings ORANGE leads as being your two 24VAC secondary windings.
You will have to fill us in on the left side of the transformers wiring as I see a definite RED and BLACK as potentially being a primary wiring set.
BUT . . .are the bundled pair of larger YELLOW wires just passing by, and not actually entering into the transformer ?
But if they are, they might be related to a second primary winding that would be associated for optionally wiring this chair to run on 220VAC . . . however the two support boards are ticked off as being for 120VAC operation.
Without a wait for your response that that aspect, in the interim get your meter in hand and set to OHMS function mode . . .not in its diode / continuity test . . .set to its lowest range IF its not being a smart / auto ranging unit.
Observe the display for what an open circuit is showing on your meter, then short the test leads together to see what a " short " reads as . . .and expecting your test lead loops resistance.
Then track down the RED & BLACK wires connector and see if you have resistance or an open circuit.
If the YELLOW wires were transformer connected, check out their associated connectors resistance.
A CONTINUANCE . . . . . . I had to leave for other more pressing tasks in the interim . . . .
BUT, I now see that " the shredder " has since come back with his "plug 'er in" and check its output voltages request.
We both, now are awaiting that info.
I also now have a better revealing photo that DOES confirm the extra wires coming into the primary side of that transformer.
https://www.electro-tech-online.com/attachments/f1a98796-dfa8-4e3a-81d5-2f31a585693f-jpeg.132996/
Therefore I tend to want to visualize a series aiding combination of the two primary windings for 220VAC operation, or a properly phased paralleling of the pair of windings, for 120 VAC operation.
OBSERVING YOUR POWER CONTROLLER BOARD . . . .of post # 43
For sure this baby boards father must have been a TREADMILL CONTROLLER. . . .due to their similarities .
Split this board down the center and the left half will be constituting a power controller.
AC power comes in at JK1 2 pin connector , then there is its rectification with the big BLACK FWB block and then its rectified DC storage at the two large black E-caps to the left. What are their capacitances and voltage ratings ? Then that DC power passes down to an un viewable POWER FET ? that the gold sheet metal screw on the center of the heat sink is mounting . . . but, its other sides companion HEAVY D1 damping diode, you are able to see.
Then there is an on /off power switching relay with its unwanted " inspector A's " green label, which we don't need! , since its blocking the relays part number, but since the rest of the unit is using 12V coil relays, we assume the same coil voltage for this relay.
Finally, we can see the output from the POWER FET's controlled output routing over to the JK4 2 pin connector that feeds the most powerful motor / or / mechanatronics associated with this chair. Finally there is that 0.08 ohm 7 watt resistor that is suspicioned to be inserted from that J4's second pin to ground . . .or . . .its being the POWER FET's source resistor to ground. Either will give a small comparison feedback voltage to reflect the degree of mechanical loading being subjected to . . . . . in order to then engage corrective feedback.
Wh a a a a a at ? . . . . .
Is there being the circus's 500 lb fat lady plopped (and that's being heave e e e e on the PLOPPED, down in that chair . . .or is it a 5 year old . . . . see the variances in loading ?
The final few things . . . .
The relay driver is Q4 and has its damping diode beside the relay
The JK5 connector and its need of isolation by the 4 O.I.'s just above it, fed by this boards custom 18 pin u/P, just above them.
Further up the board at the left as a smaller 2A 600 V round black FWB for a minor sub/ supply from its AC voltage source coming in from JK2 connector.
Its main DC storage capacitor would be the big blue E-cap above it . . . . .give us its capacitance and voltage rating.
Just to the right there is an 8 pin DIP I.C. . . .suspicioned as a dual op amp or comparator, which spits its output to the JK3 connector at top.
Can you give us its part marking, to confirm ?
The only two final items, that are fuzzy in my mind, are down at the very bottom of the relay.
Looks like two POWER plastic cased transistors ? / FET's ? mounted side by side.
Can you confirm their part numbers . . . . and they might be different . . .as in complementary pnp/npn or p /n pairs.
I am now dependent on the firstly mentioned two large black caps, in order to ascertain JK1's AC supply voltage.
If being 24VAC this certainly will be ONE of your POWERFUL 24VAC supplies, but not the 2W05's minor supply, unless it is piggy backing on one of the 24 volt windings.
OBSERVING YOUR MAIN BOARD . . . .of post # 47
This time the divisional line is across the center of the board with the POWER portion on the bottom
If our earlier studied board rated using one of your power transformers 24VAC windings, this one certainly rates using the other one.
I'm suspicioning 24VAC input from the 2 pin connector just viewable below the heat sinked FWB black block . . .OR . . .the two pin connector
with a frontal marking of V1 visible .
MYSTERY . . .? . . . why the second FWB twin unit at the 8:00clock position from it . . . .but with it . . . . not ALSO equally rating its own heat sink ?
Then the sole, largest BLUE E-cap must be one of their storage caps . . . .why is there not a duplicate second one, for the other FWB block ?
What are the blue E-caps voltage and capacitance values, with the minor cap hardly being significant for its minor storage capacity.
Just to the left, I am seeing a full blown H controller with dual opti coupler feed at the top and the TR1-TR2 POWER transistors.
This should be for the second strongest demanded motor / or / mechanatronics being utilized with this chair.
I suspicion the MOTO 2 pin connector as this controller units output 2 pin connector, with it also using 1 of the LARGE power relays .
I suspicion a second LARGE power relay used with the CX function and being outputted into the CX . . . . . 2 pin connector.
I suspicion two power relays and the two center silicone blobbed TO-220 POWER devices along with the IC to their right side as being anither motor / or/ mechanatronics controller and outputting into the F_U_D and L_D_R? pair of 2 pin connectors. How about their part #'s ?
Finally, the set of two smaller relays at the end and and their controlling the up and down recline of the chair and their feed out into the sole 2 pin end connector.( They just reverse power polarity to the motor and stop on demand . . .at that specific position. )
HEY . . . now its time for you to tell us what are the two connectors on these modules that the two ORANGE 24VAC supplies, connect into.
Also I'm now going back and BOLD RED highlighting each first word of an informational request.
NOTICED . . . .
Of no particular evidence of severe overheating of that transformer, with your nose right up to the top paper over wraps, is there any residual burnt smell ?
Your readings will determine the next steps.
73's de Edd . . . . .
I always carry a spare pair of pants when I go golfing . . . . . just in case I get a hole in one.
(Think that over vewy-vewy cawefully. . .for the other potential NEED of that second pair of pants) . . . . . . . .
Gotma
Oct 18, 2022
Hello, I have fixed a few of these chairs and I know the problem that you are having. The problem is the Torodial step down transformer has blown the thermal fuse. It is a $2 fix, but is a bit difficult to get to. Look on the MCB and find the big round thing. The black and white wires are the power in. The fuse is soldered on to one of them. 115 degree C fuse bought on ebay. Solder a new one in and you're back in business. Be careful to not damage any of the wiring on the transformer. They can get very hot and cause a fire if misshandled.
This is a bit off topic, but along with the electronics issues (thanks for that schematic, btw) I would like to know what kind of maintenance the mechanical parts need? I assume there's parts that need to be lubed or otherwise taken care of. I have not taken the back off yet, but it's starting to squeak in a few places and I want to address it before some obscure part wears out or breaks. Thanks!
Lazzerjett
Oct 24, 2022
3
I have a KingKong 5560 Massage chair, I've had it for years but used it only so often.
I moved recently and went to use my chair and power came up as normal LED's moved back and forth and I selected fitness massage and about 5 secs later got an ER message in the top of the display. I'll link a video of each of the things I found and what I learned.
After getting the ER message I started doing the standard unplug, see what's up and kept getting the same error. I then looked it up and found this blog, thank you to all the posters! The part about the thermal fuse made the most sense but if it had blown why was I getting power, so I keep reading and looked up the schematics and was still left with the thermal fuse.
I took the chair apart, video hopefully will make sense, as it will be post disassembly. I found the transformer and removed it, carefully dug into the insulation, found the Thermal fuse, not easy to dig out, and proceeded to debug.
If you're not comfortable with electricity don't do this. I plugged the chair back in, yes it needs to be unplugged when taking the chair apart for safety. Tried the same startup and got the same ER message, so then I carefully shorted the fuse leads out and tried the startup sequence again, and voila it worked and the normal massage sequence started right up. Again thank you to previous folks that posted not only the idea but the parts to fix the problem which I have now ordered. I'll post again when I do the final installation and testing of the new part. I can't upload yet, waiting on admin.
Our chair started doing the same thing recently. Would like to find someone in the Chino/Los-Angeles area to fix it.
Lazzerjett
Oct 24, 2022
3
Did you ever upload the video? My Chair has the same problem.?
Lazzerjett
Oct 24, 2022
3
View attachment 48987 Hi all: I am in the process of doing this same repair. It should be noted that removal of the board is imperative to properly servicing the transformer unless you like grappling around under the chair to remove the wire ties, retaining nut and transformer lead connectors to remove the transformer. The connectors come off with little tabs that must be raised while pulling them apart; similarly with the motor connections on back of the board. There is also 4 screws holding board to bottom of chair chassis-I found that pulling the pin off the recliner arm servo underneath permitted the chair back to be moved forward to access board cover and mounting screws. I would also suggest that one buy the barrel-type thermal cutoff as it is rated for 10 amps while the flat type only 2 or 3. This may make a big difference on warmer days or heavy chair usage. I also plan to drill some holes in the side of the board cover to allow some heat to escape from the transformer. I would suggest only the sides because dust or other debris may be able to fall in from above. I also had to undo one secondary winding and unravel it a few times to create enough room to get at the remains of the fuse. This must go back just like it was. Heat shrink around the winding solder joints should prevent any shorts after retaping it up. I am also going to bench-test the tranny before re-installing. Apparently my replacement parts (I bought 2 round ones from guy in the link above) are already in the country so I'm just waiting for them to arrive. I will try to post some pics and commentary of re-assembly (minus the cursing and expletives I'm sure will occur) when the time comes.
Any update on your fix?
MrAllroad92
Dec 25, 2024
Hello, I have fixed a few of these chairs and I know the problem that you are having. The problem is the Torodial step down transformer has blown the thermal fuse. It is a $2 fix, but is a bit difficult to get to. Look on the MCB and find the big round thing. The black and white wires are the power in. The fuse is soldered on to one of them. 115 degree C fuse bought on ebay. Solder a new one in and you're back in business. Be careful to not damage any of the wiring on the transformer. They can get very hot and cause a fire if misshandled. View attachment 33325 View attachment 33326 View attachment 33325 View attachment 33326
Any ideas on why the rollers in the back can only go up and not down, even down button makes it go up, so far that the micro switch is passed...
I have a Masse me-9268, same as the one in your picture, but different remote.
spec
Aug 11, 2025
Had to make an account to say THANK YOU!
Had the same exact diagnosis as the poster and bypassing the fuse made every single feature work! Now just gotta solder a new one on. The massage chair I have is a Micro Touch R-5 so if anyone in the future has this problem aswell, this fixed it!
