Math question for a counting circuit
kong
Sep 26, 2010
122
I'm using the 4536 timer IC
the freq is calculated by: 1/ 2.3Rt*Ct
my component values are R1: 1k C1: 1uf
f in hz
R in ohms
C in Farads
I keep messing up somehow...I get a roughly 1hz pulse from the first stage using these values, I just want to know how I got there.
Any help would be appreciated. If someone could show me their math so I can do it from now on that would be great
14,308
The 4536 can be operated with or without an internal prescaler (8 stages).depending on the state of the 8-bypass pin. If the prescaler is enabled, the signal to the counter is fin/256, The first stage of the counter divides by 2 so the output is fin/512. With your components fin=434Hz, so fin/512=0.85Hz which could explain your ibservation.
kong
Sep 26, 2010
122
I did get 434Hz, just didn't understand the rest. Are you saying the first stage of the counter divides by 512? 434/512=0.85Hz and that's the output I'm tapped into because I have the binary inputs set accordingly?
That makes sense. Very similar to 4060 expect in output stage capability.
14,308
In fact the prescaler divides by 256, the first flipflop of the counter by 2. That makes for a total pf 512.
You can disable the prescaler using the 8-bypass pin of the 4536.
kong
Sep 26, 2010
122
So with the Bypass pin 'high' with the binary inputs all set to low, shouldn't I have my 434hz signal? Because the led lights but does not noticeably blink....when I take bypass low, I get a 1hz signal, now the counter should have 9 divider stages?
Arouse1973
Adam
Dec 18, 2013
5,178
You won't see 434Hz, the eyes can't pick this up. Think about 50Hz mains light bulbs and if you can see them flicker much.
Adam
kong
Sep 26, 2010
122
I now have it backwards for some reason....when the 8-bypass is 'high' I have a steady lit LED. But when it's high, it should be dividing my 434hz signal by 512, correct? That means I should have that 0.85hz and it should be blinking.
But it's the opposite; when 8-bypass is LOW it blinks, but wouldn't that mean that the 434hz is only divided by the first divider stage? That's what I have the binary input (DCBA) set for. LLLL on the input should equal the first divider stage connected to DECODE OUT. So, 434/2=217hz. So it should still be steady (since the eye can not register) but it's blinking. So essentially it's backwards.
Any idea? Thanks to both of you, by the way.
kong
Sep 26, 2010
122
Wait, actually I took a look at the truth table and everything checks out! Somehow I got it backwards in my head.
Since I'm here I also had a similar question regarding the 567 tone decoder. I posted about it here a couple weeks back but never got a reply. There is a calculator someone put up for it on google but I'm still having trouble with the bandwidth calculation.
BW= 1070 sqrrt Vi/ fo*c2
where: Vi <200mv C2=capacitance at pin 2 (uf)
I'm more curious how the math is done long hand than the actual values for a practical circuit. I'd just like to be able to work it out on my own. Here is the link to the datasheet: http://www.jaycar.com.au/images_uploaded/LM567.PDF
Thanks again!
kong
Sep 26, 2010
122
Figured it out. Amazing what a second try can achieve.
